Ultimate LS430 picture thread
Old 12-21-20, 04:05 PM
  #2371
b16gsr
b16gsr's Avatar
Originally Posted by ItsRichie
What size wheels are you going with?
19x9 and 19x10.5.
Old 12-21-20, 04:10 PM
  #2372
mavisky
mavisky's Avatar
Willing to share offsets? I just ordered a set of 20x9 and 20x10.5 myself
Old 12-21-20, 04:40 PM
  #2373
b16gsr
b16gsr's Avatar
Low 30s front and high 30s rear if I remember right. I would have to dig back through a ton of emails.
Old 12-21-20, 04:43 PM
  #2374
mavisky
mavisky's Avatar
Interesting as I'm high 20's rear high 30's front based upon the previous owner's configuration.
Old 12-21-20, 04:47 PM
  #2375
b16gsr
b16gsr's Avatar
have any pics of previous setup? We are probably pretty close to the same. I am thinking it’s 30 or 31 front and 38 or 39 rear.
Old 12-21-20, 04:52 PM
  #2376
mavisky
mavisky's Avatar
This was the old setup on GTR wheel fenders have been trimmed front and rear on my car so you may not be able to go as aggressive if yours aren't.
20x9.5 F +40mm including spacers
20x10.5 R +25
My incoming setup is 20x9 +38 and 20x10.5 +27 which should sit a couple mm inboard both front and rear from what this setup was.
Z7USUDRV (04-01-23)
Old 12-21-20, 06:14 PM
  #2377
Ellesse
Ellesse's Avatar
19x9 and 19x10.5.
what finish is that? Gorgeous color!
Z7USUDRV (04-01-23)
Old 12-21-20, 06:18 PM
  #2378
b16gsr
b16gsr's Avatar
brushed bronze shouldn’t look too bad in pearl white.
Old 02-03-21, 01:33 PM
  #2379
ZedRe4d
ZedRe4d's Avatar
Default My new LS430
Just bought this a week ago and excited to start customizing it just a bit. Pristine, one owner, 36k miles!
The following 3 users liked this post by ZedRe4d:
carlISF (02-08-21), E46CT (04-12-22), LowkeyLS (06-21-21)
Old 02-03-21, 04:50 PM
  #2380
ChopsGS
ChopsGS's Avatar
A few new pics in the sun with the new wheels/tires...
bjchilds1 (11-30-21)
Old 02-03-21, 05:13 PM
  #2381
mavisky
mavisky's Avatar
New muffler delete went on. Have some nasty resonance in the 1600 to 2000rpm range and around the 125hz frequency. Designing a Helmholz resonator now to solve the issue hopefully.
The following 4 users liked this post by mavisky:
boostinsc (12-12-22), ChopsGS (02-03-21), LowkeyLS (06-21-21), pmesfun (02-03-21)
Old 02-03-21, 06:23 PM
  #2382
ChopsGS
ChopsGS's Avatar
Same here with the interior drone. Let us know how the Helmholtz resonators work out, and the specs of them. I did a little research a while back and IIRC, it looked like you need them to be roughly 2.5" diameter and I think 26" to 30" long.
Old 02-03-21, 06:35 PM
  #2383
mavisky
mavisky's Avatar
What you're describing is a 1/4 wave resonator. I've looked into one of those but fitting one is tricky with the spacing available. Your memory serves you correct although diameter isnt as much of a concern as length. A true Helmholz resonator consists of a primary tube and a secondary larger chamber.
My calculations are showing I'll need a 1.5" od tube at a length of 5.5" with a larger second chamber comprised of a 4" od chamber with a length of 6". Im planning on fabricating these snd having them installed in the location of each of the rear mufflers.
ChopsGS (02-03-21)
Old 02-03-21, 09:13 PM
  #2384
ma61
ma61's Avatar
Looks great!
Are those Celsior fog lights?
What have you done with the suspension, and whats the wheel and tire specs?
You're on the same wavelength as I am, looks like you've done everything I'm about to
The following 2 users liked this post by ma61:
bjchilds1 (11-30-21), ChopsGS (02-03-21)
Old 02-03-21, 10:32 PM
  #2385
ChopsGS
ChopsGS's Avatar
Originally Posted by ma61
Looks great!
They're stock fogs, just with high quality, high output yellow LED bulbs. The tail lights are Celsior however.
I'm on Fortune Auto 500 Gen 7 coilovers. Wheels are 19x8.5 +40 w/ 245/40's.
Quick Reply: Ultimate LS430 picture thread
