I'm suspecting that if you wired your DRL HID ballast directly to supply power or switch a relay from the DRL power line, its probably not getting enough voltage to trigger the ballast on or completely ignite the HID bulbs.
What you may be able to do to solve it is to find the relay trigger point of the DRL on the car and trigger the HID ballast from there, and supply the ballast with a 12V constant line separately to supply the voltage. IN any case, if the DRL bulb line is not getting 12V to the original DRL lamp bulbs, you don't want to be using it for either the trigger or the voltage supply line.
well i did order their modules and bulb out eliminators but they didnt work at all. the led kept getting only half power no matter what i did. **** it this is better anyway
