clear taillight for 01-03
#196
oh ****! so basically we juss need one more set to take that warning sign off??? i only got one set of resister also... fawkk -_- drwchicago, lemme know if you are able to get it fixed. that'll be some great news!!!!
#198
1 Post
after getting very little help via private message, it looks like it's confirmed - the new sets are an actual FIX for the tail lamp failure light.
It looks like the original two resistors that came with the initial sets were not adequate enough. IMO the manufacturers thought only 1 resistor would be enough for both the upper and lower portion of the trunk attached LED's, only to realize it was not.
the upper and lower portions of the LED's attached to quarter panel both have their own individual resistors, you don't see it because they are inside. They are able to keep them inside because the quarter body attached LED housing is much bigger than the trunk attached led housings.
#201
#205
Dances with goats
is this something i could do on my own.. im 17 years old and mechanik savy but i suck when it comes to wiring!!
mike you think you can do a write up on them with some pictures? thanks a lot!!
#206
Anyway, I really do not want to exchange the entire set because these look great, i know all the leds work, and i know they dont leak...i dont want to take the chance with a new set
I'll make my own resistance packs and post how to make your own (or I'll make some and send them to people)
#208
1 Post
I wish some of u had chimed in when I was asking for help and questions about the resistors when I was installing them. There was a good handful of u that knew what was going on with the resistors.
I could have measured the resistors during the install and would have made it a lot easier.
it's all installed now and it's a pita to take it out again.
#209
I was just saying that with the 1 resistor per side, my upper/inner lights cut off after a bit of driving. The rest of the lights work fine. I will make a separate resistor pack so I can have 2 per side like the newer packs are coming with.
#210
no biggie...I havent kept up with this thread lately so I wasnt aware the new sets came with 4 resistors...I'm familiar with resistors/wiring so its not a big deal for me to make my own
