Need instructions on removing door panels
Junier your right i forgot to add that part (it was late while i was writing the post). Jemmy if there is no sound coming out i think it could be 1 of two things. If your lucky you can just take the door of and unplug and then plug your speaker back in. This might get it working again, you might have a short or connection problem from your plugs. I had this problem with my fog lights, when i replugged them they worked once again. Or the second problem is your speaker is done and needs replacing. Silicone only helps to re-seal the torn woofer not the a dead one. Sorry bud.
Very easy to do, i just did it today and siliconed my speaker, rather then replaced it (did the same for my woofer).
1) there are 3 hex screws at the bottom of the door under the weather stripping and 1 more in the airduct hole (right near the mirrior, once you open your door).
2)there are 3 more bolts, 2 in the arm rest (1 under the bottom and 1 under the window switch cavity) and 1 hidden by the cover of the door handle cover plate. use a flat head screw driver to remove the panel in the door handle. it pops not where the lock is but at the other in where the handle finishes. you can also use the flat head to remove the window switch cavity.
after all the screws are removed, you can just snap the door off.
Thanks!
Exactly what I need to replace blown Mark Levinson front speakers! I was thinking about paying an installer, cause I didn't want to break anything! I'm on this tonight. Thanks! ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Dak148
11-15-13 10:09 PM
e-man
08-04-04 08:56 PM
