When should shocks be replaced?
When do the shocks generally need to be replaced? I have a 2001 with 57k miles (standard suspension, not air or sport). The service dept. says they may need to be replaced. Their exact words (written on the invoice) were: "Possible weak shocks - appear 'Heavy' over speed bumps." Is this something I should be concerned about?
Thanks ~ John
Thanks ~ John
When the dealer checks them and sees that they are worn out or leaking OR whenever they are in such poor condition that you can feel a noticable difference in the ride of the car.
The reason I say the second option is because they cost about $3500 just to replace the front shocks.
Here are the costs that someone else posted in the "Converting Air to Conventional Suspension".
48510-50130,STRUT Front SPORT PACKAGE: $76.71
48510-50120,STRUT Front NON-SPORT: $76.71
Cost of Sport and regular springs:
48131-50130 OEM Lexus Front Coil Spring SPORT PACKAGE: $113.38
48131-50140 OEM Lexus Front Coil Spring ROUGH ROAD PACKAGE & SPORT PACKAGE: $131.35
Air Suspension - Strut Cost:
48010-50110 Pneumatic Front W/Shock Absorber Cylinder Assembly: $985.20
Thanks everyone for your replies.
I gather from the responses that my shocks probably do not need to be replaced. They did not mention any leaks or other visible issues, and I do not know how to tell if they are worn out.
As far as determining the ride quality, I personally feel it is pretty good. However, this is my first LS and I have nothing to compare it to (other than my '97 ES, in which case it is far superior). BTW, my ES has 96k on it and there has never been any mention of the shocks (which made me suspicious of the "diagnosis" on the LS).
~ John
~ John
For standard shock, check with old school style. On each corner, push the corner a few times and let go. If the car kept bounch more than once, the shock need to be replaced.
According to Monroe, driving with a seriously worn shock absorber can lead to:
Reduced braking efficiency resulting in longer stopping distances
Reduced efficiency of Anti-Lock Braking Systems (ABS) and Electronic Stability Control (ESP)
Increased risk of skidding in the wet
Aquaplaning occurs at lower speeds
Less control when cornering or caught in a cross wind
Increased driver tiredness and reduced speed or response
Increased wear of tyres and other suspension components
Uneven/oscillating headlight level causing dazzle to on-coming drivers
Increased passenger discomfort
Increased risk of ิsnaking' when towing
I think TENNECO have written a good article on this subject:
The Hidden Danger of Worn Out Shock Absorbers
