Exhaust tips for '01
Are there any options for '04 style chrome exhaust tips for the '01? I would love to be able to spruce up the back end a bit. Thanks
madkow,
If you are still interested in selling the Lexus exhaust tips to me, pls contact me at the address below after removing the *****
*****garrywillisatgmaildotcom****
Thanks,
Thanks,
I noticed my exhaust tip faces downwards towards the groung and not straight forward like the Bippus 2003 model which point straight forward. Because there is a bend, which aftermarket tips any of you out there recommended. Brand or type?.......Just adding to this request.
I noticed my exhaust tip faces downwards towards the groung and not straight forward like the Bippus 2003 model which point straight forward. Because ther is a bend, which aftermarket tips any of you out there recommended. Brand or type?.......Just adding to this request.
what the muffler shop will do is that they will slide the new tip over the oem, and tack weld and position the new tip however you like.
depending on the shop, it may range from 100-180 w/ tip and labor.
hope that helps.
the WALD is a catback w/ removable/adjustable tip.
i dont remember the inside diameter...but i took one side off the inner clamp, so I just used the half-circle clamp with the tightening screw and dont use the other half...i'll see if i can find the wrapper that said the diameter
350ISRYDER
03-30-09 07:54 AM
minla007
18
05-18-07 07:33 AM
