headlight aiming messed up......
my headlight beams on my ls430 are side ways...instead of being - - they are kinda / / ...if that helps any... they are maybe 30 deg. sideways,... any helpon how to get them back to level?
Doesn't the manual tell you how to do that? The lights seem to be adjusted slightly to the right (in the U.S.) to avoid blinding oncoming cars. On my LS430 2006 the headlight lenses seem to be different on the left and on the right. Less glare to the left on left headlight, more light on the right side of the right headlight.
Is your AFS light flashing? Do you see any difference if you turn off AFS?
I had a similar problem lately but my lights were shinning too low.. It ended up being the rear height leveling sensor that cost me $400 to have replaced..
but here is the how to adjust headlight procedure..
As mentioned earlier, lights in the US and pretty much anywhere with left hard drive are aimed a bit to the right to avoid glare issues with oncoming drivers.
its an 03... the height is fine but the beam pattern is sideways 30 deg. instead of being flat ------ ------- they are like this
just not the crazy angle ... its hard to explain
![](http://i40.photobucket.com/albums/e204/posmotorsports/lights.jpg)
if this helps at all...
Your headlight aiming is normal.
Those are called cutoff lines.
On LHD car, they are like that to avoid blinding oncoming traffics.
They are opposite on RHD car (\\)
Normal cutoff lines on LHD car:
![](http://img143.imageshack.us/img143/9954/fixedhidtz1.jpg)
I have the same issue with my headlights! I had both assemblies changed and ever since then I have noticed the same / / issue. I thought I was crazy. The bodyshop (Lexus certified) told me they are okay, its normal. I understand about the "cutoff" but it just don't make sense? The cut off being set at an angle versus flat should not & does not affect oncoming traffic. The lights being cut at a sharp 30-45 degree angle leads me to believe what controls this should be able to be adjusted. Anyone out there have any ideas?
Yes, I understand on the spread of the beam over the road. That is not the issue. When you park against a wall or against anything flat, like a truck or van, you can clearly see the beam at a angle. And if it is oncoming traffic the reason for the angle, than why does 04-06 LS beams cut off straight across. Also the RX, GS, and ES as well? Something just does not seem correct?
