tire size change
First of all, you need to post the original size then we can tell which size is best fit.
Need to have the same diameter for the speedometer to read correctly.
There are off set of the rim to worry about also. I am still strying to understand the off set regarding fit, handling...
Then again, if you want to understand it, follow the site below and order the rime from the tire store and you are good to go.
http://www.discounttire.com/dtcs/infoTireMath.dos
The infamous 'speedometer error' is really a non-issue, IMO. Unless you are switching to a crazy tall or short tire, there is very little speedometer inaccuracy from a tire/wheel change. Just do the math and get an idea of the inaccuracy, and keep it in mind. For example, if you know that you are acutally going say, 61 MPH, or 58 MPH when your speedometer indicates 60 MPH (assuming the speedometer is accurate, which it probably isn't precisely), just keep that in mind and adjust accordingly if needed.
Here's a calculator: http://www.paspeedo.com/calculator.htm
In your case, if you switched to the tires you mentioned you'd actually be traveling a couple MPH slower than indicated at 60 MPH.
Here is a tire calculator that I always liked. It showes you a picture of the difference in tire sizes.
http://www.miata.net/garage/tirecalc.html
