04-06 LS430 60K mile service question
Here is an update on my 60K service.
I used LexTechs (http://www.lextechsofatlanta.com/)
2004 Ls430 60K Service
Service :
1 Replace engine oil and oil filter DIY
2 Reset oil replacement reminder light (if equipped) DIY
3 Replace air conditioner filter DIY
4 Replace engine air filter DIY
5 Rotate tires - N/A recently done
6 Change Wiper Blades DIY
7 Replace brake fluid
8 Re-torque drive shaft flange bolts
9 Replace Differential oil
10 Replace Power steering Fluid
11 Replace Engine Coolant
Inspect the following:
1 Measure brake pad thickness and rotor runout
2 Ball joints and dust covers
3 Body
4 Brake lines and hoses
5 Drive belts
6 Drive shaft boots
7 Engine coolant
8 Engine valve clearance (This one s just listening to the engine)
9 Exhaust pipes and mountings
10 Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses
11 Fuel tank cap gasket
12 Rack and pinion assembly
13 Steering linkage and boots
14 Transmission fluid N/A (Sealed)
15 Inspect nuts and bolts on chassis
16 Road-test vehicle
17 Charcoal Canister
18 Wheel Alignment
DIY Materials - $95
60K service $185
Total $280 Beat that
Bonus: I got the telescopic wheel movement turned off for free.
Chad and Huston at LexTechs did a great job. Huston used to work at Lexus so he knows this stuff very well. I would highly recommend these guys for any Lexus service (and for that matter Toyota as well). If you are stuck on Lexus Coffee and soft drinks then these guys keep that free for customers as well.
Disclaimer: I don't work for or associated with LexTechs
Service :
3 Body
5 Drive belts
6 Drive shaft boots
7 Engine coolant
18 Wheel Alignment
DIY Materials - $95
60K service $185
I have a low mileage car and I plan on not changing the fluid just like lexus says..........hopefully other people with higher miles can provide better info on the outcomes...I dont really worry about the tranny fluid because I have still yet to hear about a tranny going bad on a LS 430
zmoneyJD
04-10-17 02:07 PM
Moogy
05-04-11 12:28 PM
