22inch rims????
Old 02-15-14, 09:19 PM
  #46
1WILLY1
1WILLY1's Avatar
Originally Posted by username32
The biggest id run is 21" MAX, 22s Ive seen look ridiculous, might as well rally the car they are high as hell.
yea they are certainly not for everyone, I always had a thing for big wheels , lets see how they look installed, if they come across as too big I can put them for sale simple as that
Old 02-15-14, 09:20 PM
  #47
username32
username32's Avatar
What's the width and offsets?
Old 02-15-14, 09:41 PM
  #48
1WILLY1
1WILLY1's Avatar
i was sad to see they are non staggered, they are 9.5 all around I think, they are going to be a mild offset im sure.
If i like them i will be disassembling them, refinishing the faces, and getting two new lips to make them a staggered set up
9.5 in front and 10.5 in rear
Old 02-16-14, 12:35 PM
  #49
1WILLY1
1WILLY1's Avatar
checked out the specs on the back
does anyone know if 9.5 with a +38 offset will clear our brakes?
Old 02-18-14, 11:59 AM
  #50
1WILLY1
1WILLY1's Avatar
My dream of 22's has fizzled
too bad too because honestly they looked amazing.
wont clear front brakes, not worth the effort to get them to fit so they are going for sale.
Old 05-06-14, 08:55 PM
  #51
JET93
JET93's Avatar
Default My LS 430 on 22's
What offset are those? You can do 22's that clear the front break. Mine do barely but no caliber rub at all. And technically my offset is wrong. I'm about to sell these rims and do a 22 staggered with the perfect offset. Check out mine, let me know if you like.
Old 05-06-14, 08:58 PM
  #52
JET93
JET93's Avatar
I can see now. The lip is too big on those, you have to stagger that, the rim in the back fit perfectly I bet. No deep lip on the front and those would work
Old 05-06-14, 09:08 PM
  #53
1WILLY1
1WILLY1's Avatar
Those look great man , I actually sold that other set in the photos above and bought a new set which are much nicer.
Around here you will get nothing but flack for going with 22's, but dont let it bother you.
In my opinion 22's look great on these big luxury sedans.
These are 22x9.5 x 22x11- offsets unknown( I didn't check)
Attached Thumbnails 22inch rims????-20140402_175526.jpg   22inch rims????-20140402_175518.jpg
Old 05-07-14, 09:47 PM
  #54
JET93
JET93's Avatar
Default Looking good
I see I get a ruff time for 22's, but they look better and those rims do look better bro, good look. Do you get any rubb in the rear on bumps?
I'm in Chicago, you go less than 22's your not doing it right,
Old 05-07-14, 10:09 PM
  #55
1WILLY1
1WILLY1's Avatar
Thanks man
Yea the 11's in the rear had serious rubbing issues .
It was sad but I had to fold the lip and pull the rears a tiny bit, even after that they were rubbing the forward bottom plastic side moulding, so I had to dremel a little bit of it off.
I still need to rent some space in the shop and finish it off properly.
My fronts still rub a tiny bit on bumps, and they scrape the inner lining on full turns , but not enough to cause any problems , its quite minor so I might just leave it, I still have a full turning radious and am able to drive it safely.
I actually stopped liking chrome a few years ago , but these are a good quality 3 piece set that came off a Bentley, I actually really like them.
Your lucky your in the states, you have access to all kinds of great wheels , here in Canada its so hard to find good wheels.
wsinla
08-19-21 01:21 PM
jimxms2
11-07-11 01:10 AM
feldman
12-12-07 01:22 AM
ILOVEGIRLS
Wheels, Tires & Brakes Forum
05-06-04 09:35 AM
Methodical
21
09-04-03 07:12 PM
Quick Reply: 22inch rims????
