aftermarket radio in ls430?
Old 04-11-16, 05:41 AM
  #61
mfalcon
mfalcon's Avatar
Looks like a good option toantran99, what interface did you end up using to connect? Metra?
keep us posted when you're done.
Old 04-11-16, 07:39 AM
  #62
toantran99
toantran99's Avatar
No interface, just the radio. Disconnect the Mark Lev amp, use the speakers wire on the Mark Levinson amp and connect that to my aftermarket amp.
Old 04-12-16, 12:47 PM
  #63
Owczar
Owczar's Avatar
Does anyone know if audio output from Mark Levinson radio and player is digital or analog?
I am thinking to connect mirabox to my nav screen on LS430 and switching audio signal by 4 relays. But I am not sure what signal input is on the mark levinson amp. I know that amplifier is responsible for sound level, balance etc. But it will work when I switch input from radio to mirabox?
Old 04-13-16, 08:05 PM
  #64
toantran99
toantran99's Avatar
I don't think that will work, need to buy the beatsonic kit
Old 04-13-16, 11:47 PM
  #65
Owczar
Owczar's Avatar
I have seen similar solution os SC430 with ML and it works fine.
Sound volume, balance etc was regulated as before - on touch screen.
Old 04-17-16, 07:05 AM
  #66
Owczar
Owczar's Avatar
I have made wiring aux on ls430 and it works perfect. Sound quality is cery good. To input audio signal I disconnect radio signal by four relays. Volume control, balance, bass, treble etc are controled by amplifier on touch screen. When I turn to cd changer, audio from aux and cd are mixed. So to listen cd, aux should be disconnected.
Old 04-22-16, 09:21 PM
  #67
Caketoo
Caketoo's Avatar
2005 LS430 No Nav No Mark L.
Beat sonic Kit or new Amp ?
Installer tried to connect Jensen NAv system with TYTO interface. Jensen Nav w TYTO produced Sound in speakers Not in sub. His suggestion was to buy a 4/5 channel amp, run wires to all and I would have a great system. The install price would go up and I would have to buy the amp. My question is should I try the Beatsonic SLA-24A for my 05 LS430. Or go the new amp route? I think the stock factory system sounds great but just looking for best sound quality. It's roughly 200 additional to go the new amp route Vs. Buying the Beatsonic SLA-24A kit ? Any suggestions?
Old 04-27-16, 10:53 PM
  #68
toantran99
toantran99's Avatar
Go with the new amp, the Beatsonic kit is way more than $200
Old 05-14-16, 08:10 PM
  #69
espresso19
espresso19's Avatar
Good evening folks, Just had my Beatsonic and Pioneer 8200NEX installed and thought I share some pics for anyone that is contemplating adding a Pioneer. The Pioneer comes with two USB connectors one for android and one for apple but my wife and I are Android users and so the second USB is in the glove compartment hooked up to a 1TB usb hard drive with my entire music collection. I must say, I was blown away by the 8200nex as it has so many features that is going to take me at least a good month to get around to messing with them. But for now just the basics. The sound is much better than stock as the Pioneer comes with its own equalizer and brings out the sound on my cd quality tracks. Even the radio now sounds better as the head unit is able to pick up HD stations. Enjoy the pics
2006 Lexus LS430
Lost all Steering wheel functions:
Cost: Not cheap
Pioneer 8200NEX $1,200
Beatsonic $390
USB/HDMI Cig Connector $50
Install $180
TexasLS430 (02-23-17)
Old 05-15-16, 01:02 AM
  #70
Geols430
Geols430's Avatar
I have done like what you have said in your write up and I have installed a Kenwood system. But again I am also in a great disappointment coz of loosing Steering wheel controls
****{I finally completed the installation of my aftermarket head unit in my 2001 LS430 non-Nav. I learned quite a lot during this project so I am attaching a PDF file that contains my learnings. I retained my OEM amp and speakers and I used the TYTO-01 to interface my new head unit.
Thanks to a number of folks on this forum for their answers to my questions! I hope this helps someone.
Installation Post.pdf}}}}
Old 05-15-16, 01:07 AM
  #71
Geols430
Geols430's Avatar
Hey Moto, Do you have any solution for this. Have installed aftermarket radio (kenwood) in 03 LS430, but not able to find any harness to connect to steering wheel controls
Old 05-17-16, 10:01 PM
  #72
DriftGirl
DriftGirl's Avatar
Started here...
My Old Setup...
Then this....
Newest setup using Beatsonic faceplate...
Old 05-17-16, 11:45 PM
  #73
cerushio31
cerushio31's Avatar
Can someone tell me the difference between the $300+ beatsonic dash kit vs the $20 metra kit for non-navi models?
Old 05-19-16, 07:15 AM
  #74
Owczar
Owczar's Avatar
I have installed mirabox on my LS430 with mark levinson audio. Everythink works fine. I am able to listen mp3/flac and play all most popular video formats form USB - steering by app on the phone. I could also connect my phone by miracast/airplay. Sound quality is very good. Chipset
Old 05-30-16, 12:59 PM
  #75
toantran99
toantran99's Avatar
My aftermarket radio. Did not go with the Beatsonic kit.
Quick Reply: aftermarket radio in ls430?
