Subwoofers?
#33
Obviously you have enough speakers to hear them inside the house across the street. Did you remove the oem sub to act as sort of a port? Is the sound muffled any? Did you dynamat your trunk for rattles?
#34
yes i did take out the factory sub and my bass does not sound muffled at all.. when it plays you can hear and feel every single note....and i did not dynamat my trunk yet and for some strange reason my trunk doesn't really rattle all that much... it rattles but not to the point where its ridiculous
#35
The Lexus Mark Levinson is probably the best stock sound system I have ever heard. Its DSP gives a very pleasurable listening experience.. The comments about lack of bass at loud volumes is not present in my LS 430. You may want to check where your ASL and BASS levels are set.. This system does not distort even a max volume.. It is amazing.. But it could still be louder..
I have installed the Ultimate Lockpick which allows me to have an alternate input.. Such as DVD, MP3, etc.. I am using a player that plays multiple formats. I am splitting the output of this player into the stock Mark Levinson system as well into a Hifonics Olympus amplifier that separates the sub output signal down to any frequency I want.. 80 - 250 hz.. I run it at around 120Hz... this amp then drives two 10 inch Hifonic subs in an isobaric enclosure that can be removed when necessary.. When I want to bump..and show the system off, I use my alternate signal source which plays everything.. SAT, DVD, MP3, FM and TV broadcast..
jpv7774
12-26-15 11:06 AM
