UL Air suspension acting weird?
I mentally went thru the whole car, really the air shock is the only item that is a lot more expensive then a normal car (Camry). But that shock in general last a long time, I mean most normal shocks don't last more then 50k~75k miles. Price wise, sure it is A LOT more then the shock on a Camry, but it is inline with highend shocks. The Ohlins shocks on my WRX STi now is $500 each, but they don't last more then 100k miles. The OEM UL air shock is available online for $750 wholesale. It is not THAT much more.
Other then that, if you are smart about it, long term wise, comparing buying a used 3 years old LS430 UL and a new Camry V6 XLE, and drive them for 10 years/150k miles. The price difference is very small, the difference in enjoyment level is HUGE.
brought it to the dealer and got them to diagnose the problem and they can't seem to find anything wrong with the suspension!! They said all the height sensors are fine and are in working order. Is there a specific suspension sensor that i should be asking about? Cause i still seem to feel the car go in and out of stiffness..
is there a thread where someone else here had the same problem?
Some dealership can be pretty dumb, you have to tell them specifically what to do/check.
3UZ-FEEEE
A little more detail? Height does go down when at freeway speed. Also, it sometimes "settles" itself when parked. Usually, once the cars starts, the car will level itself out. Look for the opposing corner. If the front left is low, then the right rear is low. The corners seems to be tied into each other.
the front stays the same its always the back going up and stays up when i drive on freeway or regular roads then i have to put it on a different setting then back to my normal setting to make it stay the setting i want, but in a week it does the samething?
