DIY For Transmission Flush
#46
As for changing the ATX filter - fortunately it's probably unnecessary. Engine oil filters primarily remove combustion byproducts that would otherwise interfere with lubrication - metal shavings are a very minor secondary component that the filter catches and isn't the reason why they need changing regularly. No combustion happens in the ATX, and any shavings will mostly collect in the pan. So it's very unlikely that you'll have a clogged filter situation.
Finally, if you're super lazy and have an 01-03, sucking out the ATF through the dipstick and replacing, then repeating 3x times over the period of a few weeks between each change will get you 90% of the benefit with very little work. It'll be more than good enough to protect your ATX which is what it's all about in the end (unless you really love wrenching on stuff).
#47
Older toyotas used dexron transmission fluid. Looks like your 96 es300 should be dexronIII (or the latest and greatest version of dexron). Follow owners manual to be sure.
#48
If the fluid has never been changed you may end up with a slipping transmission after changing fluid. Burnt smell could be clutches worn out because fluid was not doing its job. If you do change fluid and transmission slips a band aide that may work or may not work is Lucus transmission additive. Burnt smell is not good for a transmission. Another bad sign, if you do decide to change fluid and remove trans pan, gray sludge in bottom of pan is a sign of clutch wear.
Good Luck
#49
Hi all. I have 2001 LS430, with 82000 miles on it. I have the full maintenance history as this car has been maintained by local lexus dealer by previous owner.
1) So, does my car require a transmission service/flush/fluid change, and if yes, at what mileage intervals? I dont have my manual immediately available to check.
2) on the maintenance record there are two dealer service comments. One dated in 2004, and the other in 2008. Both comments state:
"15k or 1 year whichever comes first. REPL eng oil&filter, air filter. Diagnos and inspect. Drain trans pan & repl diff fluid (NO trans fluid '04, GX470, LX470, LS430) insp brake, tires, batt, belts, hoes, etc...." This tranny comment dont' make sense to me. I checked with dealer and they claim tran fluid was likely done.
I have no issues with my car, tranny or otherwise and I am planning a long road to trip in two weeks where I will definitley put at least 3500 miles on the car. I was thinking about having the tranny serviced before I go, but now not sure if I should or even need to spend money on this type of service.
What do you think?
What do you think?
#50
What do you think?
What do you think?
With all that said, I'd go over your service records with a service manager at the dealership and verify the transmission fluid had been being changed at regular intervals. I personally don't think it would hurt it to change it and clean the pan and filter. The pan has a giant magnet in there and it catch most metalic shavings. You can get by (unless you let the dealer do it) by washing the filter and re-filling the fluid with Totota Type IV Transmission fluid.
My fist LS-400 had 82,000 miles on it when I bought it and I was on the freeway and when I'd let up on the gas totally, then accellerate again, I felt the car "Shudder" when the tranny went back into play. Scared me to death. I took it and had a friend drop the pan, clean it all up and replace with new Toyota Type IV fluid and NEVER hadn another issue.
Good luck and enjoy the trip
#51
Thanks Carnut. I was able to review my owners maintenance manual and it does say to replace tran fluid at 60k, but only if the car is driven under "special driving conditions", such as towing, snow, mud, dirt road conditions", otherwise not required. Than again at 120k it recommends another change, but again only if car is driven under these extreme conditions. I am confident that my car was not driven under these extreme conditions, and driven about 7900 miles a year.
But as a precaution I am planning to speak to the service manager and reveiw the history, because it does appear to me that the previous owner followed the recommended maintenance schedule to the "T", and there is a record for the tran fluid change at about 66k miles. So, I need to go to dealer to see full details.
I had the same uncertainty with the timing belt service. I am under the 90k miles, but past the 7 year mark for this service. On the history report it said that in 2009 the TB service was recommended at 72k miles to customer, and that a full time belt svcs was done. But there were additional comments that "customer declined" TB svcs, so it doesn't make sense. And to boot, on my car front engine compartment frame, hidden under the radiator black plastic cover, I found a lexus sticker which reads "last timing belt service/record", done March 2009 at about 72k miles, and even has mechanics initials and dealer location #. I also checked with service dept and they reviewed detailed history and confirmed that based on total cost that customer paid which was about $700 just for parts that the TB was in fact done. He said total cost was close to $1600.
I think I'm in good condition with Tranny, but because I am preparing for this long road trip I want to be sure to do whatever recommended svcs that may need to be done before I hit the road.
Thanks again!
Thanks again!
#52
Thanks again!
Thanks again!
I agree you need to determine if yours has been changed. If so, you are good for another 100,000 miles or more.
Good luck.
#53
I had a Toyota dealer flush my trans out at about 90k miles. Replace it with WS fluid. Car is doing fine.
I have a 2004 ML
I have a 2004 ML
#54
Sorry for bring a dead topic back to life but my E55 stated lifetime ATF as well, but go and search 'failed transmission Mercedes' and draw your own conclusions. FWIW, MB has recently changed it stance to servicing the trans at 40k.
stuckincal (10-05-19)
#55
The fluid is not life time. I have an 05 and the fluid that came out of the trans was black I have 127000 miles using a pump and drain we are only able to do 2 qts at a time. Be doing it again next weekend till the fluid turns red again. There is no such thing as lifetime fluid. I would not trust the fluid to go beyond 50000 miles.
#56
If I ever said the '05 Lexus tranny fluid was lifetime, I may have had too many. The Dealerships may say that, but I do not agree with that theory. My 05 LS-430 has 71,000 on it and never a problem with the original fluid. At this time I plan to have it ALL flushed out and replaced at about 75,000 miles just to give me peace of mind.
#58
Otherwise, if you can't run with the big dogs, may as well lay on the porch.
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
#59
Some people run their car engines without changing the oil - it usually catches up to them at around the 25k mile mark. If car warranties were 15k miles, they'd call it "world oil" and remove the dipstick. Doesn't change the fact that changing the oil well before failure is advisable. And that lubricant failure always comes at some point.
Hyundai's will probably barely make it to 150k before major servicing is needed. The 430 will run much longer than that, so different rules apply than for shorter design life cars. Just like for a 15k car that never "needs" an oil change.
