DIY For Transmission Flush
#91
Unless you have some kind of super duty use that is hard for me to imagine doing with a 430 I am okay with 100,000 miles for an inspection as long as the time frame is within a reasonable amount of years.
My theory is that the sealed transmission are made that way because fluid such as Toyota WS is highly Hygroscopic. I would certainly not mix it with other fluids.
I see no reason to believe that moisture somehow cooks or boils water out the tranny fluid due to heat.
If this is not true of brake fluid why would this happen inside an A761E? Someone earlier had espoused this belief.
On the company (NOT LEXUS) that does complete flushes they get it all out and replace it with BG Fluid, NOT TOYOTA WS fluid, and then recommend to their customers to have it done every 30,000 miles. They want $225.00 to do this. I'm not really sure how they "Inspect" our tranny fluid since there is no dip-stick. What do they inspect it for ? I hear great things about BG products, but a Lexus Dealership is not the one's that use it. So, I'm between a rock and a hard spot. I'd like to get it done now, at 80,000 miles than wait till 100,000 miles. Everybody that's Lexus Tech's and friends that are Lexus Techs keep telling me to "Leave it alone". So, that may be just what I do. Time will tell. And I don't know how I would mix tranny fluids since I have no dip-stick.
#92
I like BG stuff but would not consider doing that.
On an older LS I had a Toyota dealer do a flush with a BG Machine that they claimed was loaded up with T-IV. I think they were actully telling the truth!
Since I own an older 430 I have not researched your exact issue but if I were in your position I would pump out a sample size of fluid to send to Blackstone Labs & see the results of their testing.
#93
Thanks in advance.
#94
This was well over a decade ago with a LS400 and everything I could put my hands on to read recommended T-IV . Dealerships machine was loaded w T-IV and price was a tad over $100.00 so all systems go.
Did not know condition of the fluid prior to the flush but only did drain & refills for the next 135,000 miles.
In our fellow owners case I would not mix non-WS with a WS fluid despite their claims.
#95
#96
Not sure why people are saying you can't drain the fluid on the 04-06 transmissions... There is a drain plug on the pan just like any normal automatic transmission. I have drained and refilled mine 4 times now. If you jack the front end up and let the car sit for a while, you can get almost 3 quarts out (the manual says only about 1.5 to 2 quarts). I have a funnel and tube that I run down from the engine bay that I use to get the new fluid into the transmission so that I don't have to mess with fluid transfer pumps.
Yeah, draining and refilling a few times is a lot more tedious, but I feel it is the safest way to change the transmission fluid. I am glad I did it because my fluid was really dark on my first drain and refill but now it is red again.
#97
Think I may be osterizied here if I again post what we used for % drain and refills. Lots more fluid comes out of an 6 speed than an old a340E. Basically in the 3 drain & refills you will have replaced over 60% of the fluid.
#98
#100
WIth all that said, I'd like to put the risk factor on a Lexus Dealership, but I don't know what they are really going to do. I was told for a drain and fill it was just over $100 bucks. The other place to do a complete BG Flush is $225. From my experience, I would do a total flush with your car since you may not know what kind of fluid is in it. And, to start some more agony, I think it's time to do a complete "Coolant Flush" and refill.
#101
thanks for the advice Carnut, i have already done timing belt ,water pump, coolant and spark plugs. So i guess when I do my trans I will do my rear diff also would you suggest oem fluid or mobil 1
#102
Since my last post, I got to thinking and forgot to ask, "Is your transmission sealed" like the 2004-2006 LS-430's ???? I also called one of my best friends that is General Manager of a Buick/GMC Dealership and asked him his opinion on changing the coolant and the transmission fluid. He consulted with his transmission expert and he adamately said, "DO NOT CHANGE YOUR TRANSMISSION FLUID". So, here we go again. I was also advised to "NOT CHANGE MY COOLANT".
Now, with all this said, and I am as old school as anybody else on this Forum, "EVERYONE" that has advised me against changing my coolant, my transmission fluid etc., are very good friends and have nothing whatsover to gain, or lose, by giving me this advice. As I've posted before, even my next door neighbor works for Lexus and he said, "DO NOT CHANGE YOUR TRANSMISSION FLUID". Is this not a mess or what ? It sure makes it difficult to make the decision to FORCE somebody to change those fluids when I have so many friends that have nothing to gain or lose telling me to "leave it alone". I have done about all the homework I can stand on this issue and by the way, my friend that is General Manager over the Buick /GMC Store uses BG Products.
Sorry, but I'm throwing in the towell until I can catch the right Technician at Lexus and get the real "skinny" on this topic. Good luck with whatever you do. I'd use BG in my differential.
#103
If it makes anyone feel any better we have this identical debate in a BMW Forum for 5 Series E60 models which use a ZF 6 HP26.
The debate there was solved to my satisfaction when I found a video of a German Owner taking his car to a ZF service center & filming their service procedure. They not only dumped the tranny pan & all fluid but disassembled and cleaned the valve body! All for €425 after a mere 35,000 km.
ZF made the damn thing so my thought is that they know more than BMW on how to care for it!
E60's are a transmission nightmare here in the states & BMW tells owners over & over, Do Not Service!!
Friend owned my 545I and had a 35 mile work commute each way. Despite this BMW had to pay for a new Valve Body (Mechatronics in BMW speak) under warranty as I bought the car due to a system failure before the warranty timed out at 97,000 miles. $2600 service they claim.
#104
