Overdrive noise
Overdrive noise
Hello all. I have an 02 LS430 ultra with 77k miles. (bought it at 73k).
When the car shifts into overdrive I can hear a whining noise in the driveline. It is most noticable at 40-45mph and I assume it is in the transmission because I can shift it into drive and put the car under similar load (light-moderate) and it is silent.
Also, much more noticable in very cold weather.
Anyone ever hear of this issue or am I the only lucky one? Thanks.
Have you checked the fluid level? When was the fluid last changed? I would start by changing the transmission and differential fluids if you don't know when they were last changed. The Owners Manual lists the recommended fluids and change intervals.
Losiracer2
54
11-27-18 10:22 AM
