Reliability of HID fog lights
Thanks again!
Your retro looks great, good job!
I am a virgin at these HID stuff, please excuse my noob questions. All our Lexuses came stock with HID (see my sigs), but I want to put 9006 HID into my LS430's fog, all of your help is greatly appreciated
Can you be a little more specific with the cars, which year and model # of RX and LS? LS430? RX330?
Mine was direct plug and play but you do have to take the fender skirt out part way for excess to the fog light housing to install the kits.
It is people like you who make forum very useful, thank you
Anything perfect always takes forever to do.
I got that, but who make the best harness?
I found 2 different types of OEM Denso ballasts, do you know how they perform differently?
http://hidexpert.com/pxeneco_kit.html
http://hidexpert.com/poem_kit.html
so is it correct to say all hid bulbs are D2R and D2S, all the different bases are just rebased onto those bulbs?
From the way it looks from the link I posted above and from what you said, the slim ballast are from 01-05, then 06+ the ballast became even smaller and black color. Am I right?
I understand that, thank you.
once I understand everything, installation would be easy.
Do you know if the D2R and D4R bulbs are interchangable? Meaning they have the same base? And how do they look?
Thanks for all of your help!
3. 9006 rebased D2R bulbs. Oem fogs use the 9006 halogen bulb. HID bulbs come as D2R (for reflector type headlight such as the 01-03 LS430) and D2S (which is used in projector type headlights like the 04-06 LS430).
So you'll be using the D2R bulb that is rebased to fit as a 9006 bulbs.
[QUOTE=BNR34;3532318]It is people like you who make forum very useful, thank you
The more you know, the more you're inclined to spend (and save)
I don't it matters much since most of them use the bosch relays.
Both of our vendors are having a sale and the kits include the harness.
I'd rather support our vendors since they support CL
https://www.clublexus.com/forums/sho...d.php?t=341998
https://www.clublexus.com/forums/sho...d.php?t=337486
seems like GSteg answered part of the questions.
d4r/d4s
d2r/d2s
http://hidexpert.com/poem_kit.html[/COLOR]
Yes, it's starts out that way, but gets modified to fit other conventional halogen applications.
The 2 notches in the neck are your conventional D2R/D2S bulbs.
The tabs you see sticking out are for non-D2R/D2R types:
Yes regarding the slim ballast from the links you provided.
Installation is not hard at all. It's a matter of plugging in all the wires to:
1. Battery
2. factory fog harness
3. hid bulbs in the fog light
If we're ever in your area at Corona del Mar Beach (right?)-wife and kids at the beach, I don't mind meeting up with you and lend a hand
d4r/d4s
d2r/d2s
1. Battery
No problem.
Definitely the RX and LS use the slim ballasts b/c when I bought the headlights, the slim ballasts came with them.
I'm going to safely assume the 2001+ models, that's what I noticed so far.
I don't know about the ES, but the older 2000> GS use those older one-the bigger black ballast.
Make sure you get the 9006 relay harness if you're going to wire them up for the fogs. Check the classifieds or even Cliffud, he's a vendor now
Here's my LS430 retro for my GS:
To LS430 Owner that installed HID fog lights
How long ago did you install the lights?
has anyone got prblem yet?
Where did you place your Ballast?
I installed mine on 4 May drove to San Diego from Las Vegas on Sunday and one of the ballast broke. Had to replace the ballast...
Thank you very much, I really appreciate your help.
Yeah I am in the Del Mar area. If I have more questions or need your help, will definitely let you know
The one I bought it cost me $69.98 shipped. So far so good with the replacement and all other light I bought work good.
garyr
04-17-08 02:25 PM
