Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
- Lexus IS: How to Replace Your Tail Light Assembly
Step by step instructions for do-it-yourself repairs
How to replace tail lamp bulb? Help please!
I measured the OUTER tail light assemblies of both my '01 and '06 and they are the same dimensions, so they should swap easily. Note, a word of caution: if you replace the outer tail light assemblies on your '01 - '03 with the LED lights '04 - '06 version, the inner tail light assembly (on the rear of the trunk lid) do not interchange - they are different sizes on the '01- '03 model vs. the '04 - '06 model. You would still have regular bulbs on the inner tail light assembly (and different lenses) with LEDs on the outer tail light assembly. The light emitted from the two different types of lights (LEDs and bulbs side-by-side, and with different lenses) could be noticeable.
i have same problem. I thought there was but it doesn’t. I took it apart. Turns out the bulb has two filaments in it. Sylvania 7443.
Mobius1
12-22-16 12:17 PM
