Will thse 18" Work Euroline S2h Wheels Fit my LS430?
I own a 2001 LS430 standard model and was wondering if thse rims would fit and clear the BB's without any problems in both front and rears and no fender adjustments. The car is not lowered and all stock.
Front 7.5 wide
Rear 8.0 wide +33 offset
5x114
The tires on them now are 245/40/18, I know the tires to match would be 245/45/18 to stay within stock specs. Will these tires do okay other than run a little faster. Was thinking of buying a used set of the rims and tires together.
Any feedback would be appreciated. I tried posting in the wheel forum and got no respomse. Thought I try here.
Thanks, DanozLS430....
Front 7.5 wide
5x114
These look like racinstyle's rims but in a 18" size.
https://www.clublexus.com/forums/sho...&highlight=S2h
So? I should be okay with these with no fender mods? Is the tires size okay also?
DanozLS430....
I tried on the Work Euroline S2h wheels and they did not fit. The rim rubbed on the front big brakes and did not bother to go forward with spacer. I was wondering if racinstyle changed out his front brake set up. Too bad, there rims looked really nice. I'm going back to plan B which is my TRD SC430 rims which looks similar in style. I got them all new in the box and looking for some good tires. Here is a pic of my TRD rim, just trying on for BBK clearance. no rubbing issues with this one. What do you guys think about this style? It still got the plastic packing rim protector around the rim edge.
DanozLS430...
DanozLS430...
singernak
04-06-16 03:07 PM
