A/C filter replacement
Hello folks,
I just wanted to say thank you for all of the tech tips available to date! I recently got an alert of "A/C Filter Replacement" on my 01 LS430. Has anyone got this alert before and what did you do to get rid of the alert? Where did you get the filter from to perform its replacement? I guess I would also need to service the A/C system with freon?
Thank you all very much in advance for any tech tips and guidance!
Cheapest place I found online and I had multiple excellent experiences with:
$24 for the cabin AC filter.
http://www.factorylexusparts.com/ser...BIN-AIR/Detail
To reset the "A/C Filter Replacement" warning light, press and hold down the "OFF" button on the AC system for 4 seconds. See page 11 of the attached owner's manual. Or see your own copy of the owner's manual.
Dances with goats
to turn off the the alert simply hold the off button where the a/c is and wait till u here a beep.. that means you changed your filter, so onto that you do need to change the filter
open the bottom glove box and remove the back of it and the filter should be over there simply remove and put in a new one,
not sure where you can get a new filter but maybe online...
good luck
let us know if you need more info and on that note
WELCOME TO CL!!
good luck
WELCOME TO CL!!
No need for freon replacement!
Hello folks,
Call the dealer and ask them about timelines for freon replacement for the LS430, they can tell you when to expect to add/replace it or tell you if you need to now based on miles or years the car is old. Again no need to replace the freon but if you have questions about it just ask the dealer(local Lexus) and they can help you with your question without you paying out.
All the best.
L.G.N.M
Were to get filter!
Hello folks,
I myself always buy from the dealership, its not economical but, I dont second guess if I got the right product when I buy from the dealership!
L.G.N.M
You can get the filter were the first person to respond to your post said to or check auto part stores or you can go to the local dealership in your area. You can check Lexus/Toyota dealerships. Call both dealerships before driving to them to see if they carry the filter for your car as well as calling the local auto parts stores to see if they carry the filter for your car.
L.G.N.M
L.G.N.M
The place I suggested above is an actual Lexus dealer, but they sell some of their parts online for half price. The best of both world in my opinion.
Factory Parts...
BNR34 is right on target... I have dealt with Matt Molini at Lexus of Roseville (factorylexusparts.com) and purchased several parts from them. It's always a pleasant experience, they ship quickly (usually 2 days or less) and the parts are OEM Lexus parts so there are no issues with getting cheap knockoff parts. I highly recommend them.
Wow!
L.G.N.M
99alta
03-29-15 01:07 PM
agunjal
03-06-12 05:42 PM
