Any tip for DIY spark plug change?
Hey guy what going on... well im planing ing the come week to change my spark plugs and was wondering if anyone can give me a few pointer... anything i should know about doing this service to 03 LS430??? If i correct the plug need to be gaped to 0.44 right?? And what spark plugs you guys thinks is best NGK OR DENSO???
Hi
The gap is already set on the plugs... there are two types of Denso plugs, the long life plug and the performance plug, the long life is pre set at 0.7mm while the long life is set at 0.4mm
![Agreed](https://www.clublexus.com/forums/images/smilies/boink.gif)
How often should I replace the spark plugs? The Lexus website simply suggests 5000 mile service without further details. Thank you. (It's a 2001 LS430 with almost 100k miles.)
The Iridiums (and some platinum) are rated for 100K, but unless you're experiencing some premature hesitation or rough idling, then I would say 100K is about right. I would almost venture to say if you use a premium grade fuel, then over 100K is fine.
The only important tip with changing the spark plugs, guide then in by hand, then wrench tighten. Common mistake is that right from the start the DIY'r wants to tighten the plugs with the wrench. If you're off a little bit, you can strip or rethread, and then you've crapped it.
You've removed the coil pack already and extracting the plugs now right, or you're just about the remove the coil pack? The coil packs are just held in place by two little bolts. Remove those, then you have access to the plugs. Use a spark plug socket which is deeper and had a rubber o-ring inside that will hold the plugs inside the socket. Before turning, take a non-flammable compressed air can and spray into the chamber to blow any dirt out so that once the plug is removed, the dirt doesn't fall into the cylinder. Turn counter-clockwise and the plugs should pop right loose and come out. It's straightforward.
So i am about to change my Spark Plugs on my '02 ls430. Do i need to change the wires as well if so what wires do you guys recommend. I see every one here says to get the Denso plug? Is there an online site i can order this cheap?
PS: car has 181k miles.
Bringing this thread alive again...
How many of you guys use torque wrenches when installing your spark plugs? And at what rate? I've had people tell me they do and don't use torque wrenches with removing their plugs. It's time to change, and I have some free time later today to do some maintenance.
