My AC smell any ideas?
has anyone tried this?? and does it work?? Looks interesting.. tempted to test it out..
I just changed my cabin filter this morning. I ordered a replacement one from Sewell (great service!!) and including shipping it was $34.00. I took a look see into my lower glove box and it was totally understandable on how to replace the filter. Took me all of 2 minutes to do. The old one was wretched btw and the air does seem to smell better...probably psychological tho. =))
Sprayed 1 part bleach 20 parts water in the filter slot. Let it sit for 30 minutes with the fan off and windows down. Then turned the car on for 30 minutes with all the windows down. Bleach did the trick.
Takes a total of 2 hours for the smell to go away. Kind of like setting off a bug fogger in the house. Now all is fine. Just what I did, not giving anyone any advice.
I have an 01' UL and I had changed the cabin filter (the one behind the glove box) for about 3 months now.
NOW, everytime I start up the car, it gives me a message of Change A/C Filter. I wonder it means the air filter by the engine compartment or the cabin filter by the glove box or some other filter somewhere I don't know about. Please help....
If you are running the a/c with the air "recirculating" in the vehicle, then stop. Let fresh air in. Do not run it on auto (this setting shut the doors for outside air to come in). You want to run the a/c with fresh air coming into vehicle. When you run the a/c with the door closed. all you are doing is circulating the stagnant air that is cooped up inside of the vehicle. This causes mildew to form around the evaporator. Pulling fresh air into vehicle will resolve this problem.
My UL has this issue from time to time. Each time I turn on the a/c and it is very hot & especially humid out, I would get the foul smell for a short time, then it would clear up. So all I would have to do is to leave the a/c setting on fresh air coming into vehicle and the smell would be gone. The smell returns only after the a/c is run for a long period of time with the outside vents closed.
So every now and then, let fresh air into vehicle when you are running the air conditioning.
It's all explained in the Owner's Manual.
Actually, my 04 LS, while in AUTO mode is mostly showing "Outside", switching to "Recirculate" mostly in times when rapid cooling is needed. Lexus has thought this "Auto" thing out pretty well, yet still allows setting our own preferences. I was told years ago by a Lexus tech that always leaving it in AUTO (and never turning A/C to OFF) will prevent the smell. I took that advice, after replacing the cabin filter, and have never had the smell again
again anyone know where the evaporator is? because i tried everything and it still doesn't work i bought this foam can and it said spray into the evaporator which i dont know where it located. i have an idea it should be near the power steering but not sure.
