cd 6 disc changer read error 3?
I'm having the same problem. I was in the process of ejecting a CD and it appears that it has malfunctioned and got stuck trying to eject the CD. How can I help the player eject the disc?
disconnect your battery. cd will eject when you reconnect I think
If believe if you hold the eject button down for an extended period it will try to eject all. also, I had cd's stuck once. I was able to see one of the cds and use tweezers to remove. That fixed the logjam and everything worked fine since.
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
Thanks everyone. I did hold down the Eject button but one disc was jammed. I was able to see the stuck disc and pulled it out with a pair of hemostats. Once I did that, all the discs ejected one after the other. I was then able to successfully reload them one at a time. All seems good now.
Thanks for all of your suggestions.
Shea
Shea
Jontay
07-22-21 08:23 AM
