Side Mirrors LED Light Install w/ Pix
#76
NP!
The glove box and middle console use the same bulbs that are used for your foot and door handle lights. They are not worth the PIA it will take to get to them for a swap IMO, but hey you can be the first to take a crak at it.
#77
Wouldn't
this
WLED-xHP5 Wedge Base Bulb
Miniature Wedge Base Bulb(194/168 type) with 5 High Power SMD LEDs
12 VDC, 360 Viewing Angle, Polarized bulb
Select LED color
$ 5.95
be better than this?
WLED-xHP High Power LED bulb
12 VDC Wedge Base bulb (194/168 type)
With 1 High Power LED
Polarized bulb, Available in Pure White, Blue, Green, Red and Amber
$ 4.95
And it is just a dollar more. Anyone tried this? Is it brighter?
Reference: Search WELD on this page
this
Select LED color
$ 5.95
$ 4.95
#78
Yes b/c it has more LED's but you have to be mindful fo the size of the bulb housing when swaping bulbs for LED's. The trunk, doors, park, mirrors and tag all use 194 but the areas are tight. So the LED's may not fit or light corvers won't snap back on due to the LED's being to big.
#79
i knew this thread is up for a while. never bother to check this out until after i changed my customer mirror led light...
regards to the instructions from the op, you don't have to take off the surround of the mirror. infact i separate the mirror by pulling the bottom. then slowly slide it down because there is 2 hooks on the top that you don't want to break just by pulling.
and taking off the center mount it is not necessary...once you got the mirror lens off just loosen the screws for the housing...afterwards you can pop off the light at the bottom
i don't recommend using a credit card to pop the light from the bottom, no matter how careful you are...i look at how it is mounted it is not worth it to chance scratching up the bottom
#80
LED's
About 7 or 8 months ago i switched out all my 194's with some ebay LED's. about 3 or 4 weeks later they began to flicker and or go out.. the seller warranted them (never would have thought) and they continue to do the same thing.. now i do live in fl so there's an occasional rain storm and i've got 1 L715 beating up the trunk most of the time so i can understand 1 or 2 issues but not constant.. Lesson is don't get the cheap **** as i'm going to try another brand today and see ...
Holla
Holla
#81
so i just tried, and failed miserably at replacing the license plate lights from the trunk area. son of a * that shiz sucked dude. so i didn't want to just rip off the carpet from the inside trunk release handle and the little trunk light so i just gave up. is there a trick to getting the trunk lid carpet liner stuff off of the emergency release handle and little trunk light just to the left of the release handle without screwing anything up or having a very difficult time putting it all back again?? thanks,
#82
Sojah you need to pop all of the button screws out and then work the trunk carpet around the handle. I know its a PITA but that what you have to do when you don;t have hobbit hands. Get the wife to to do swap the bulb if you done want to pull off the trunk carpet, BTW make sure you are buying 12V bulbs too.
#83
yeah, i got the proper bulbs, and i can get all the trunk screws off and access the right side bulb no prob, but i don't even think my skinny asian wife could get to the left bulb without taking off more of the carpet. so if i work the carpet out thats around the handle and even the light is it easy to get the carpet back around the light and trunk release handle to look proper again??
#85
nice ^ pic, yeah lately i just get frustrated and start pulling harder until desired or undesired effect is reached. like those side mirror puddle lights; i completely ripped the passenger side one out, but nothing a little super glue won't/didn't fix... now i just have to sell the car before the led burns out... shhhh....
#86
I used the Wled-whp's for my plate lights. They look MINT. Not to bright imo. I will be doing the mirror lights and revers lights as well. I'm not touching the interior lights. I like the soft glow on the inside of the car.
Great write up. This is a great mod for what I am doing with the car. I'm just freshening up the factory look. (sport wheels,led tails, grille, and these LED lights) I would even recomend this to guys that are 100% bone stock. It just makes the whole car look newer!
#87
good luck, Sojah. Ganbatte
#90
