Wood trim replacement
My wife and I are like soooooo close to finding the LS we want, but this recent one we've seen has the front passenger side power window trim wood color variance issue. It's black interior with the "burnt" dark wood. The one with dark edges. All the pieces inside are relatively the same shade, except for the front passengers. It almost looks like the piece was replaced at some point because it's almost the normal burchwood color. It stands out soooo much when you look over.
Anyway, my question, does anyone know how easy it is to replace that part, and where to buy the part? Is the part wood with the switch, or is the wood separate and you would buy just the wood trim but keep the switch?
Thanks.
Thanks.
I am almost certain that you can sepparate the wood trim from the switch - On my current LS I can.
I looked at the parts diagram and did not find the sepparate part for the trim though. Call the dealer and ask them about it. It shouldn't be too expensive (<$100 I guess).
intermec
06-24-21 08:08 PM
xcelr8
SC- 1st Gen (1992-2000)
09-03-07 05:11 PM
