Flickering lights
Hello everyone. 2001 Ultra Luxury. When the lights are on the navi screen stats flickering. Actually the background color starts changing - like I am using the **** left of the steering wheel. But if I put this **** a little back untill it clicks (navi background color is black) everything is OK.
What could that be?
P.S. The problem starts only when lights are on.
What could that be?
The background color change is normal (if this is what you are referring to as your "flickering"). When your light sensor indicates that the outside light is inadequate it switches on your headlights and by doing that it switches your navi color to white to give you a brighter navi screen for night driving, if you switch it slightly back it will turn to the black background again. Its just to make it easier to read at night, but for me its way to bright with a white background so I have my **** set to max before it clicks over. Hope that makes sense and that is what you mean
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
Hi, thanks for reply. That is not what I mean. When the **** is all the way up (white navi background) and the lights are on the navi background color starts flickering between white and black background like 2-3 times a second. And this persists until I unclick the **** to black navi background. I hope this time I explained it right.
