04 LS430 Tire pressure
On the 2004 LS430 does it have A low tire pressure indicator one of my tire went down to 26-PSI and nothing came up to tell me this car came with anything like that thanks
Tpms
I think that if somehow both of your fronts let's say are losing pressure at the same rate, you will not trigger a low warning. Also, the pressure loss in each wheel has to be under 26 psi. It's really measuring for "gross" pressure loss, not a variance of 6 psi. I mean, I could be wrong.
Since the pressure is not measured directly, I went and got myself a set of four (4) "Tireminders" for measuring the 30-33 range. So, if the pressure drops below 28, I'll be warned.
