Changed My Fog Lights
Old 11-07-08, 04:32 PM
Tee
Tee's Avatar
Default Changed My Fog Lights
To yellow bulbs by.....
Luminics JDM Yellow (9006)
I like this look over the stock off white color, and have always like how the yellow w/ HID's looked on the GS & IS.
Old 11-07-08, 04:45 PM
blacksc400
Car Chat Moderator
blacksc400's Avatar
Looks good, but kind of dark,
I have a set of HID 3000K yellow fogs, wanna buy them?
Old 11-07-08, 05:41 PM
AlexusAnja
AlexusAnja's Avatar
Yeah, looks kind of dark. Do they serve a purpose (for fog) or are they purely for looks? I would think that they might be too dark if needed to put to use.
Old 11-07-08, 05:51 PM
Tee
Tee's Avatar
Far as the brightness, they are pretty bright! My camera setting may have something to do with it.
This thread http://www.clubcivic.com/board/showp...65&postcount=1 has pics of the yellow bulbs in action (much better than mine) and show they birghtness better. I can see that they are on while driving vs the stock ones.
Old 11-07-08, 09:15 PM
SH212
Dances with goats
SH212's Avatar
looks good... but i cant stress this enough
DROP IT LIKE ITS HOT!!!!!!!!!
Old 11-07-08, 09:25 PM
airtime
airtime's Avatar
I may go this route too with the yellow fog. I want it purely for function not for looks. Was it hard to swap out (can you reach from below or did you have to remove the wheel well plastic?).
Also, how much was the bulb? an eBay item?
Old 11-07-08, 09:26 PM
airtime
airtime's Avatar
How much? PM me.
Old 11-08-08, 10:52 AM
Tee
Tee's Avatar
They were easy to change out, the only thing that slows you down is removing the corner panels under the car. Once you do that just reach up, twist the buld connector to unlock and remove the bulb. Make sure you don't touch the bulbs with your fingers when swaping them out. Yes you can get them off of ebay, I bought mine from this guy.
http://cgi.ebay.com/ebaymotors/_Car-...1%7C240%3A1318
Old 11-09-08, 07:49 AM
Tee
Tee's Avatar
Default More Pics
(Different exposures)
Old 11-09-08, 10:40 AM
xuserx04
xuserx04's Avatar
Mine is out on the right side. Any walkthrough so i can change them myself?
thx
Old 11-09-08, 10:47 AM
BIGGZ
BIGGZ's Avatar
nice man.i've got yellow fogs too.but they arent that bright.so i was gonna take one of the HID's from my GS and put them on the LS.i tried to remove the bulbs,but it wouldnt turn.was yours hard to turn?
Old 11-09-08, 01:42 PM
Tee
Tee's Avatar
thx
It is very easy to do, the LS comes with a tool box ion the left side inside the the trunk.
-There are two little wrenches, use the bigger one and the bigger end to take the bolt screws off the under body panels on each corner of the car.
-Then reach up and twist the buld connector to unlock and remove the bulb.
-Depress the tab to release the bulb from the connector (Make sure you don't touch the bulbs with your fingers when swaping them out) then put the new bulb in tightly and reach up twist to lock into place.
-Repeat for the other side of the car, it's crazy easy!!!
Very easy to turn.
Old 11-09-08, 02:29 PM
BIGGZ
BIGGZ's Avatar
damn,something might be wrong with mines the.i'll give it a try later.thanks.
Old 11-09-08, 10:32 PM
blacksc400
Car Chat Moderator
blacksc400's Avatar
I didn't even open my buttom cover when installing my HIDs in the fogs, I just open the wheel wall, 2 screws.
Well, I got skinny arms.
Old 11-10-08, 08:22 AM
junjdm
junjdm's Avatar
looks good...i was gonna do that...but decided to go HID instead
Quick Reply: Changed My Fog Lights
