Really weird occurrence on the highway....
Old 11-10-08, 01:59 PM
jcat_350
jcat_350's Avatar
Default Really weird occurrence on the highway....
So i was driving my father's LS430 the other night, merging onto the highway. Upon the hard acceleration getting up to speed, the sunroof spontaneously opened on its own. This ever happen to anyone/is there a reason for it?
i just thought that was so weird.
Old 11-10-08, 07:06 PM
bonafyd
bonafyd's Avatar
That is very weird...if it happens again i would take it to the dealer if i we're you.
Old 11-10-08, 08:25 PM
SH212
Dances with goats
SH212's Avatar
holy ish
thats real wierd... i would go to a dealer with that
Old 11-10-08, 08:33 PM
big_blzr94
big_blzr94's Avatar
thats some crazy torque man......
take that to the dealer
Old 11-11-08, 04:38 AM
sojah
sojah's Avatar
i've been rolling my window up (after pressing the auto up) and hit the blinker and the window stopped about halfway up and then went back down... its happened like 2 times in 3 years... hmmm...
Old 11-11-08, 03:18 PM
KILLERGS4
KILLERGS4's Avatar
most likely if you/dealer can't duplicate the problem, they can't do anything to fix it... thank goodness it's not your car... haha..
Old 11-11-08, 03:55 PM
jcat_350
jcat_350's Avatar
haha well dealer is out of the picture...2001 with 120k, i dont even remember where they purchased it from originally (bought used for a company vehicle). It is my father's car but i'm more well-versed in the lexus side of things. I doubt he accelerates like i do anyways so it shouldn't be a big deal
Old 11-12-08, 09:58 AM
lnguyenh
lnguyenh's Avatar
Sounds like electric issue, your power source was disconnected for a split second. If you disconnect your battery and reconnect it, you will more likely get the same symptom.
Old 11-13-08, 07:30 PM
bigcory
bigcory's Avatar
if you think thats the cause, check for corrosion on the battery terminals and tight connections with the fuse box.
Old 11-14-08, 05:01 AM
lnguyenh
lnguyenh's Avatar
Not my issue although corrosion on the battery terminals while driving will not cause electronic surge.
Anyway, good luck to the owner.
Old 11-14-08, 07:54 AM
junjdm
junjdm's Avatar
its a ghost? lol.....cars got a mind of its own....
Old 11-14-08, 08:21 AM
mwbuck
mwbuck's Avatar
Probably needs a new battery. When the batteries start to go on these cars, all sorts of weird things happen. CD player randomly shuts off, transmission randomly acts weird, etc.
Old 11-14-08, 11:56 AM
Rice
Rice's Avatar
How fast were you going?
After a certain speed the car will first open sunroof and then if you go faster, pop a trunk in order to generate some downforce and prevent lift-off.
Old 11-14-08, 08:21 PM
KILLERGS4
KILLERGS4's Avatar
i had issue with no sound coming from cd/radio/navi... once i restarted the car, everything was fine... not issue w/ battery.
Old 11-15-08, 06:42 PM
bigcory
bigcory's Avatar
If there is excessive corrosion, it can actually cause the wire to break into two. Look over the battery and make sure the wires are nice and tight. Tug on it a little. I had a battery cable break off from corrosion before (and that was the cause of my pontiac stalling). Corrosion will also be more of an issue if any aftermarket wires have been added with cheap connections on them.
Simple thing to look at first...
Quick Reply: Really weird occurrence on the highway....
