Change Of Lowering Springs Advice...
Juction Produce or YouZealand SS kit and call it a day.
Best of all, you can still retain your current drop springs with the SS kit and you'll get and extra 1" drop at all 4 corners (total of 2" drop).
The SS kits will set you back about $500-600. Add that to the cost of your DF210 drop springs and the total would come out to less then a set of coilovers or air.
I think you may have mistaken the SSkit for a bodykit. It's actually a drop kit (drop brackets). Here's a link to my SSkit install.
https://www.clublexus.com/forums/ls4...ce-ss-kit.html
to the op, not trying to thread jack. so my apologies
if so.
The SSkit is something like spacers if you want to think of it that way..how it works is 2 spacers go in the front and a bracket goes over the rear lower strut mount and it basicaly pushes everything upward so when you put the car back on the ground it's lower...i hope you can figure out what i'm trying to say, it seems technical but it's really not.
the SSkit works with stock 17inch rims or higher and stock suspension, aftermarket springs or coilovers.
P.S. I had pics of my car with the SSkit on stocks but i deleted my photobucket. i'm running my SSkit with stock springs and it rides beautiful.
i will be putting teins on nextyear with my SSkit.
efini_kid
21
10-04-05 03:00 PM
