Change Of Lowering Springs Advice...
Currently my car is dropped on Tanabe DF210 Springs which gives the car a 1.0" drop all around... i have 20x9"F and 20x10.5R rims and i wanted to drop my car a little lower.. I was thinking about buying the L-Sportline Lowering springs which would drop the car 1.2" all the way around... look at the pictures of my car and tell me what you think i should do....
Juction Produce or YouZealand SS kit and call it a day.
Best of all, you can still retain your current drop springs with the SS kit and you'll get and extra 1" drop at all 4 corners (total of 2" drop).
The SS kits will set you back about $500-600. Add that to the cost of your DF210 drop springs and the total would come out to less then a set of coilovers or air.
Wait. I just noticed that you have parking sensors which I think means you have an UL. I was under the impression that you couldn't put springs on an UL because of the air.
i understand what your saying..... my main issue is that the back of the car sits a little lower then the front because of my system and i want the front to be lower so that it looks level.... everytime i step on the gas the back drops and the front kinda lifts up.....
my car doesn't have airbags... it has the parking sensors and the radar camera and the headlight washers just like the UL....
