04 - 06 LS430 owners, does your glovebox light stay on?
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
My wife noticed some time ago that the light in the glovebox stays on when its closed... you can barely see it through a crack at the top of the glovebox. Its hard to see but (especially) if you're in a very dark area its visible even from the driver's seat.
Has anyone else noticed this issue in their LS or do I just have a faulty toggle switch? Mine is a 2005 Ultra but don't think that makes a diffence (but might since wood and leather on the box cover may be different).
I know that the light in the glove box and center console will only come on when the park or headlights are on, once they go out so will the glove box & center console.
Never noticed, but I would say you have a faulty toggle switch. Don't see a reason why Lexus would not put a switch in there to turn light off, when my 1995 Civic had a switch for the glove box.
Forum Administrator
If someone remembers in the evening, peek over and see if you see light coming out of the box in your LS430.
Saw your thread last night Dave and checked it out this morning.
Like what AlexusAnja+Tee said, the glove box lights up only when the parking lights are on.
There's a toggle switch in the upper right corner that turns it off when the glove box is closed.
Guess you might have to play with that one.
Me, I've never had to use the interior lights for more than 5 or 6 minutes, just to read something. If I want to read longer, I'll turn the reading lights on.
Forum Administrator
OK I tested it tonight on the way back from dinner. The light comes on when headlights are turned on and they stay on. They do not dim when the dash lights are turned to full dark and are a set of orange / yellowish lights similar to the ambient lighting in the footwells, but brighter.
I also couldn't find any toggle switch around the edge of the glovebox that I could manually press / depress to turn them on or off, will try again in the AM.
Well the ambient lights in the footwells and overhead stay on at all times (or at least at night when i have noticed them before). I would assume ambient lighting all around (including the glove box) would do the same. LED run on very little energy, a car battery would last a long time running these lights with out any regen from an alternator.
Mine is an 05, if I remember, i'll try to take a look tonight when I leave work.
2upFZ1
05-26-09 09:49 AM
