Fuel Economy Highway - getting only 22-23 max
I would have to disagree with using cruise to get better mileage. If you were on a perfectly flat highway, this might be true. On the typical highways we have in California with a lot of rolling hills and grades, cruise control uses more fuel by over-compensating to keep a steady speed. I find that my mileage goes down by a couple of mpg in all my vehicles when I leave it on regardless of the terrain. What I normally do is to use it over the flat terrain and go back to manual for the hills. I find that by speeding up slightly before the hill and then gradually bleeding off the speed on the hill, I get the best mileage.
Here's a section from a web site on hypermiling:
41) Constant throttle position cruising
Once up to speed, pick a throttle position and hold it.
Advantages: more efficient than using the cruise control (which varies throttle position frequently and wastes fuel on hills).
Disadvantages: less efficient than "driving with load" (DWL) / "target driving" (where the throttle is eased on inclines).
42) Cruise control - when to use it
Set the cruise control if you're the type of driver whose speed creeps up higher and higher the longer you're on the road, or if you have difficulty holding a steady speed (it wanders up and down).
But realize that cruise control is just a band aid for those behaviours. Generally it's less efficient than constant throttle driving, and much less efficient than "driving with load" / "target driving".
43) Cruise control - when not to use it
Only use cruise control on flat roads. On hilly roads, cruise responds to changes in grade - by feeding in more throttle on the uphill and releasing on the descent - in the exact opposite way an efficient driver would.
Steve
Steve
So it's back to a case of pay now, or pay later.
It should be noted that OCTANE is NOT an ingredient. It is only a NUMBER. The number does not tell you what is in the gas. The number tells you how the gas behaves. Ethanol contains zero octane molecules, but has an octane rating of 110. E85 has an octane rating of 105.
Some of the higher octane gas ( these days ) is being cut with ethanol to give the higher octane number... which will give lower MPG... but at the same time it is cleaner burning, and cleaner for your car.
So when I buy ethonol up here in Canada its states that it is 87 octane, what do they cut it with to bring it down from 110? I always knew it was a good thing to run the odd tank of ethanol in the winter but please shed some more light on us. Thank You
Great answer and thank you.
3UZ-FEEEE
Hi Folks,
Drove from VA to DE - about 200 miles. All highway driving for the most part but the 03 Ls430 could not manage anything over 23 MPG. Speed was between 60 -80mph...just cruising and never pushing the car. AC was off most of the time. Tire inflation about 33 PSI. Was NOT using Power or Snow mode. Car just had the 60K servicing done by Lexus...
I have seen many folks her talk about 26-29mpg on long highway trips. What could be the problem?
Thanks!
Viper
Thanks!
Viper
I think that is one element people almost always overlook.
ls430lover
07-24-13 08:48 PM
