BC Coilovers and Wheels are ON!!!
Old 02-17-09, 08:10 PM
vbspunger
vbspunger's Avatar
yes they are dual ajustable.
Old 02-17-09, 08:33 PM
Swagga82
Swagga82's Avatar
Vbspunger,
how low would you say your car is, you said u can go 1.5inchs lower so i am guessing u are dropped 1.5inches now... ?????
Old 02-18-09, 08:34 AM
vbspunger
vbspunger's Avatar
Originally Posted by Swagga82
Vbspunger,
I couldn't tell you exactly how much im lowered right now, probably almost two inches or so but these things still have alot of thread left. with the dual ajustability it still has a ways to go. i could probably almost sit the frame on the ground.
Old 02-18-09, 08:48 AM
Swagga82
Swagga82's Avatar
oh ok thank you ... i will look into those springs after I'm done with the Tanabes
Old 02-19-09, 10:25 PM
mea902
mea902's Avatar
love it. what's the offset of ur wheels?
Old 02-20-09, 06:35 AM
vbspunger
vbspunger's Avatar
the wheels are 19x9 +25 and 19x10 +25
Old 02-20-09, 07:12 AM
junjdm
junjdm's Avatar
Originally Posted by beangrower
i think 19's look good if u slam it.
that's jus me though. i like the style of wheels though. different from most ls' u see here.
yup
Old 09-02-10, 05:49 AM
CelsiorAUS
CelsiorAUS's Avatar
Can you explain what rings i should adjust. What does the top ring adjustment do and the bottom. Which one should i do first.
I just got these and am installing tomorrow
Old 09-02-10, 05:50 AM
CelsiorAUS
CelsiorAUS's Avatar
Also, Did you shave roll front or rear fenders?
Old 09-13-10, 08:20 AM
fergo308
fergo308's Avatar
The top ring is the spring preload -best set by a suspension place if you want the best results. preload can be adjusted for each corner to cornerweight the car,and also to change ride height is it's your only adjustment on the strut.
The bottom ring is for ride height,which is varied by changing the overall length of the strut.
Justin...
Old 09-13-10, 10:41 AM
otis_jzs
otis_jzs's Avatar
What if any fender mods did u do?
Blumagik
04-21-17 10:54 AM
Javi1782
Suspension and Brakes
20
03-26-13 12:12 PM
koolcat
SC- 1st Gen (1992-2000)
32
08-09-11 11:16 AM
bonafyd
06-08-09 03:17 AM
laobo979
16
03-18-09 11:28 AM
Quick Reply: BC Coilovers and Wheels are ON!!!
