01 LS430 UL Low Oil Pressure
hey guys, my dads LS has been parked up for about a week now, I went to go start it up and the battery was dead, so i got it boosted and then when i put the car in drive the low oil pressure message came up. I shut it off and checked the oil which was low, so i topped it up and then tried again, but the low oil pressure light still comes on. Im going to scan it right now and see what comes up, it is pretty old and has about 300,000 km on it. Any ideas? Thanks in advance
Might have to do with the type of Oil you have in the unit. Multi grade is used to help oil circulate upon startup. This could be the reason. Plus you said it has sat for a week. What you did not say is how long the light stayed on. A min or so is not a big deal on a loose engine. Also the Filter could be dirty causing oil not to get to the engine..
Many of us are using Mobil 1 oil, 5-20W and change it ever 5k miles max.. With high mileage on you car, you might take the hint.
If the oil filter is completely clogged the internal design of the system will bypass the oil filter so you will still have circulation. I personally wouldn't use 5w20 if the manual recommends 5w30, that means the oil is thinner when hot possibly reducing pressure and not providing full protection.
