Need some help the change A/C filter light keeps coming on!!
So I changed my air filter because it said it was due soon and now ever since I changed it. The system check still says I need a new A/C filter. Everything connnected and I went thru the nav system to tell it I changed everything. Can somebody share some info, good look!!!
You have to turn the ignition switch on, then turn the A/C system on. Then press and hold the off button for approx 4 seconds and a bell will chime and the instrument panel will say 'A/C filter reset'.
