need help changing a/c filter
my 04 ls430 told me that my a/c filter needed to be replaced. I was going to take it to the dealer but i figured if it is not too hard i will try and do it myself. If someone has changed the filter before can they help me out?? thanks you guys are great
it's fairly easy, open the lower glove box, toward to the back in the middle, you are able to removed the black panel, then you will able see the blower assembly, you just slide the clip over, then replace the filter, and make sure look on the filter, it has arrow up, make sure that's facing up. I hope this will help you.
