headligth cleaning???
not inside, but i would try some meguirs plastX to clean the outside up which often times takes some of the foggy ness away, unless you actually have moisture build up on the inside... this stuff is like 5$ and kicks the crap out of anything else. can be found at any automotive store.
Another vote for Plastx. That stuff is amazing. If the lights are still hazy, wet sand them with some very fine grit sand paper (1500, 2000, etc.) and then use Plastx again.
JMIG118
05-29-08 10:03 PM
