LS460 wheels on a LS430
Whaddya think. Good buy?? Worth it?? Anybody done it before??
http://philadelphia.craigslist.org/pts/1143373328.html
From calculation
Well it stick out too far for what I want. I think it would stick out about as far as your old 20s, which would look weird for OEM wheels.
From my memory, the thinnest adapter I could find was 15mm, the 19 x 8 460's wheels I want have offset of +35mm, and they are 8" wide. So compare to my OEM 18s that is 7.5" wide with a +45mm offset, it would stick out 31.35mm more then the stock 18s. Which was way too much for me, the max I want it to stick out is 15mm.
Andy, I calculated.......
The LS460's OEM 19s on 15mm adapter will stick out the exact amount as the 20 x 8.5 +26 wheels you are considering. Which is too much for an OEM wheels, it is ok to go aggressive on an aftermarket wheels, but I think it looks weird to stick an OEM wheel way out there. The answer is 81.95mm from the hub to the face of the wheel.
But these are on the OEM 19s though, the OP was asking about the 460's OEM 18s, I don't know the spec on those.
Not sure on the specs but nevertheless a good buy?? Even if i cant make them look right with adapters maybe someone will like the look of it on there LS, GS or even IS. Maybe???
