How to access door speaker?
I have an 04 LS430 with ML. My right front door speaker sometimes vibrates with certain low frequencies so I want to tighten the screws.
I am assuming I have to remove the door panel to access the speaker. Has anyone done this?
i have an issue with my front passenger window switch (or the wood piece surrounding it) vibrating. Anyone know if this is a piece that can be taken out with out removing the door panel?
Make sure its not the window switch that vibrating before you take the panel off. I have traced my noise back to the actual window switch.
gtstcactus
02-11-14 07:29 AM
