Wheel fitment- 20x10 +37 275/30/20
Hi,
I'm in the market for some wheels for my 04 LS430.
would this size fit in the rear?
20x10 +37 275/30/20
I will be lowered on Tein CS.
I was wondering if it this size will stick out a bit. Or will it be flush?
the fronts I am sure they will fit-
20x8.5 +38 245/35/20
thanks in advance!
20x10 +37 275/30/20
thanks in advance!
thanks Dr. Jekyll
Can anyone else confirm this? (not that I don't believe you Dr.)
Or even better if someone has some wheels in this fitment can post them up?
I checked out the 20 inch wheel thread for the LS and I didn't see anyone running this offset.
thanks again!
thanks again!
You sir have a very nice ride!
I actually saw your post:
https://www.clublexus.com/forums/ls4...ed-wheels.html
you noted:
Front wheel is 20x8.5 with 38mm offset
Rear wheel is 20x9.5 with 43mm offset
so I just wasn't sure if 20x10 +37 275/30/20 would be the same fitment.
Walds...my favorite
you noted:
Walds...my favorite
Here you go:
20x9 +46 245/35
20x10 +39 275/30
https://www.clublexus.com/forums/ls4...ck-it-out.html
All his fenders are stock, when he dumped his car on the ground, his rear tire barely touch the fender lip. So if you put a +37 on the rear, it is fine, unless you plan to drive your car with a REALLY low ride height
20x9 +46 245/35
20x10 +39 275/30
It will because on the same wheels with a 10" width, Wald has them spaced out to +37, so basically yeah, it will work. Maybe I'll give a more descriptive answer next time so it doesn't sound like just an educated guess. Hope this helps and good luck finding the wheels you like.
Big Thanks BNR34 and Dr. Jekyll
You guys know your stuff!
I've been a lurker for some time and just got my LS late last year.
time to start modding.
Just wanted to make sure I get the right wheels and offset.
thanks again guys!
thanks again guys!
thanks Jav for the pics of your wheels. They look really good.
BNR34- once I get some wheels and the suspension I will definitely post some pics up.
thanks to all!
thanks to all!
