Fix For Sunvisor Squeek
Both front sunvisors on our 2002 LS430 have recently developed a horrible "squeek" which sounds more like an angry crow. The noise occurs with the rotation of the sunvisor on the plastic tube when the visor is rotated up and down either in or out of the clip above the inside rearview miror. I've used a silicon lubricant as far down the tube as the visor will extend without significant improvement. The noise does not occur with rotation of the visor to cover the side window. Only when the visor is rotated up and down (in any position, extended or not).
Suggestions???
Thanks,
HRP
Suggestions???
Thanks,
HRP
Wacogal20 (08-20-24)
I have the same problem on my '04 Ls430. It's worse in hot weather. I've also tried lithium spray, silicone,etc. on the shaft, but it doesn't slide out far enough to do the whole thing. Can't get anyone to explain how to get the visor off the shaft - which seems to be required to fix it. There's got to be a way to get it apart to get at the whole thing. I won't spend the $ to replace the visors (both squeak), so I guess I''try harder to figure out how to get it apart ..
Walt
Walt
Warm weather
Walt
Walt
Put some vasoline in the needle, and then use the tip to insert into the little opening on the visor roller. Squeeze out a good amount, not over oozing, and then roll the piece around and around to get it lubricated. Solves the problem instantly.
What I don't know if how long it will last and will the heat end up melting the jelly and will it then ooze (leak) out? Thus far, not bad. And mine was baby sent, so I have a little baby sent in car now...
Maybe someone can recommend something better than vasoline, but you can use the same needle to do the filling.
Hi, I have the same problem in this Texas weather. When you said the little opening on the visor roller, do you mean the space between the plastic stem and the cloth?
I've got that problem too, but it doesn't bother me too muchYou guy are probably better off using something like the Shin etsu grease. (Seems to be all the rage) The vaseline will probably thin out when it gets hot.
Does it make noise when you drive? If not, maybe leave it alone? The noise only lasts a quick second, but who am I kidding. It would probably bother me too.
I didn't even notice this til you guys mentioned it. Certainly doesn't bother me enough to bother with it, and it doesn't make noise once it is in position. Not only that, the increased resistance means I can leave it in more positions without it vibrating loose.
Sun Visor Squeak
Sorry for resurrecting this old thread, but I wondered if anyone had a solution for squeaking sun visors. Every time I rotate the panels to place the sunshade across the dash, both are creaking loudly on this otherwise silent vehicle. (Mind you, there's no noise while driving. Only when the visors are being positioned). Many thanks!
Suggestions???
Thanks,
HRP
Suggestions???
Thanks,
HRP
Toyota Body Grease
Petroleum based products are not compatible with plastics.
Had same visor squeak with 1999 LS400.
Applied Toyota Body Grease and problem solved.
Durable lubricant and compatible with plastics.
Excellent for use in steering wheel tilt and telescopic mechanisms.
Not inexpensive, but the good stuff that is compatible with plastic
