DIY 01 LS430 Pop/Popping/Crack/Cracking/Clunk/Clunking/Clack/Clacking noise front
Old 06-08-09, 07:03 AM
speedemon
speedemon's Avatar
Default DIY 01 LS430 Pop/Popping/Crack/Cracking/Clunk/Clunking/Clack/Clacking noise front
DIY '01 LS430 Pop/Popping/Crack/Cracking/Clunk/Clunking/Clack/Clacking noise from front suspension
I have an 01 LS430 Ultra with the Air Suspension about 100k miles, it had recently developed a Pop/Popping/Crack/Cracking/Clunk/Clunking/Clack/Clacking noise from front suspension primarily from what I could tell as the drivers side (left side of the car). I usually only heard the noise while driving slow making parking lot type maneuvers with the wheel turned rather far and braking slightly, then the same noise when it settled back down when reversing into a space or something similar. It also occurred occasionally when I was banging a right hand sweeping exit ramp, I heard it from the Drivers side but just as a single pop (left side of the car) Fearing the worst I assumed it was either a ball joint or one of the control arms, neither of which on one of these cars is cheap I'm sure.
1. to check the ball joints jack up the vehicle with the lower control arm supported (use a block of wood as a contact point) so you can have a more realistic loading of the components in the suspension, make sure you bring it up enough to also put a jack stand under it to keep yourself safe. Ball joints are checked by grabbing the tire by the very top and very bottom and try to rock it top to bottom, there should be no movement, if there is and it feels loose or detached at a particular point get it checked out, if there is a lot, you may want to consider getting it towed to a shop because if it lets go you will wreck.
2. to check the tie rods inner and outer do the same test as above but grab the tire by the very left and right, if there is slight fluid movement that it likely normal because you are literally turning the wheel and the other wheel ever so slightly, what you are looking for here is an abnormal movement or play from left to right where it feels almost like it is detached from the rack, if it feels firm or no play you are fine.
3. Visual inspection, remove the tire, if you don't have an air compressor and an impact you will need to lower it down to remove the lugs. Once the lugs are loose raise it back up and remove the rim/tire, make sure there is nothing obviously wrong or loose.
4. some people have described the brake rattle clips causing issue or similar noises, now is the time to check that, a brake job on this car is extremely easy, all you have to do is pull the the little retaining clip in the rod that retains the pads and applies pressure to the pads anti rattle spring steel, it looks like an I, you can check the tension, while I was there I decided to lube the contact points on the pad backing and the caliper and reassembled.
5. next is check all the nuts and bolts that you can reach and get either a wrench or a socket on, remove the reusable cotter pins from the tie rod and upper control arm attaching points and tweak them a little bit to ensure they are tight then reinstall the cotter pins if they don't go in try another hole if they still don't go in tweak the nut just a little further, also tighten or try to tighten anything else you can see, caliper bolts spindle/knuckle bolts, stay away from the air ride sensor and other sensors for the abs and brake wear. If anything feels loose or you can tweak is just a bit by all means do it, some can move a click or 2 on a ratchet, most of these will be extremely tight and unmovable with a regular ratchet or wrench.
What I found on mine happened to be the forward nut on the lower control arm, I think it was a 19mm, I used a ratchet and a socket and tried to tweak it and it popped/cracked so in order to actually crank it down I used the handle of my jack on the end of my ratchet as a cheater bar to get extra leverage, you might be able to make these points too tight with a cheater bar so you might want to use a torque bar, I found a torque setting of 166 ft lbs, from one of these threads, but didn't use it myself because that is pretty damn tight, and probably about all I can do with a breaker bar.
I put it back together and checked the other side and everything was tight so I buttoned it up and went for a spin, messed around in a couple parking lots and banged some long sweepers way too fast and my noise is gone.
I then smiled all the way home thinking about the $1500 I just saved on control arms because you know that's what the shop would have sold me if I didn't know anything about cars, honestly I have no idea how people that just drop their car off to be fixed can actually afford it especially when dealing with potentially crooked mechanics. I've worked in a couple shops and you'd be surprised.
Prices from the stealer
lower control arm $390
labor to install $300
alignment $170
total $860 for one side
total $1550 for both sides plus taxes and shop fees (ouch!)
I hope this helps someone save some money.
Old 06-08-09, 05:42 PM
Nauticalx
Nauticalx's Avatar
Same issue here, has a vibration at lower highway speeds and turned out that the idiots at firestone left the lower a-arm adjusting nut too loose and the whole thing was moving. We got it tightened down and the popping noise previously thought to be from the brakes as well as the vibration, disappeared! Firestone sucks!
Old 06-08-09, 05:43 PM
Nauticalx
Nauticalx's Avatar
Oh, any ideas on what shops are best at alignment? I have an indie shop local here but was wondering what chains people trust with respect to alignments on our less-than-common vehicles...
Old 03-23-13, 04:00 PM
ipwn
ipwn's Avatar
Hi which forward nut are you referring to?
Old 03-23-13, 06:32 PM
speedemon
speedemon's Avatar
Zombie thread, back from the dead!
Can't see the while part number in the pic but it's the 8069c nut, the main lower control arm nut, take care not to move the bolt as I think that will change your alignment.
Old 03-23-13, 06:49 PM
jayclapp
jayclapp's Avatar
I had the exact same noises in my 04 UL. In my case, that turned out to be the lower control arm bushing, which fixed the problem when replaced. I agree that there may be different causes of this type of noise, but this was the cause of mine.
Old 03-24-13, 11:04 AM
gemineye
gemineye's Avatar
Another data point:
I had the exact same noise that Speedemon discusses in the original posting of this thread. After taking my car to 3 suspension specialist shops, it turns out the noise (clunking and popping at low speeds while turning, and vibrations at higher speeds) was caused by exactly what Speedemon describes (i.e., the nut for the caster/camber eccentric adjustment bolt was loose). After the shop tightened it down, the clunking/popping noises went away.
I then took it for an alignment as i was concerned that the caster/camber/toe settings were not within spec. Result: caster and camber were in spec, and the front toe setting only required a small adjustment. It has been one months since being aligned and the noise has yet to come back, and I am VERY happy about that......that noise was horrendous! I can now drive my LS without embarrassment of the hideous noises it was making.
Great post Speedemon.
Old 08-02-15, 02:21 PM
hanamannie
hanamannie's Avatar
I have exact same problem on my 01 LS430 Ultra with 85k miles. My mechanic was unable to determine what causes the noise. Thank you so much Speedemon for your valuable write up. It helped me save a lot of Money, I expected to spend up to two thousand dollars to fix this problem but with your detail repair instructions, it costs less than $50.00
Old 06-03-19, 05:31 PM
hoisted
hoisted's Avatar
I know I'm reviving a thread that was long dead, but this seems to describe my exact issue! Does someone have a diagram with the bolt that might need to be tightened?
Old 10-12-19, 10:43 AM
Lzam
Lzam's Avatar
Did you ever figure out your problem I have the exact same issue and I have checked every thing except the eccentric bolt?
audphile1
10-11-14 08:58 PM
RXGS
Suspension and Brakes
18
10-27-13 08:30 PM
phesa
04-14-11 05:42 AM
alp325
10-19-10 06:14 AM
Neophyte2b
10-19-09 12:07 AM
Quick Reply: DIY 01 LS430 Pop/Popping/Crack/Cracking/Clunk/Clunking/Clack/Clacking noise front
