Won't go on L-Mode
Old 07-02-09 | 11:30 AM
junjdm's Avatar
junjdm
Default Won't go on L-Mode
Anyone here w/ the data controller system.....I have a quick question. Today I was trying to put my car on L-Mode and it could go on L-Mode. If I am correct while on "9", you hold the bottom right button and it should go to L-Mode. (of course when your on the option of Extra-Down Mode) which I am. This is the first time I've seen this.
On setting "9"....I hold the bottom right button.....and mine does absolutely nothing...but just blinks on "9"
Anyone w/ ideas? Bad controller? Could it be the weather? Its too hot outside? Cuz it is over 100+ today......just a thought.....any advice would help. Thanks
Old 07-02-09 | 12:46 PM
REV-01's Avatar
REV-01
probably someone press high on the stock switch...i will kick the L setting out. just reprogram it.
Old 07-02-09 | 01:56 PM
junjdm's Avatar
junjdm
how do I reprogram it? By holding the top left button when i start the car?
Old 07-02-09 | 04:59 PM
sojah's Avatar
sojah
yes, just like you said ^ ^ ^, and yes to previous of while all 9's are flashing by holding down the lower right hand button will bring mines to an 'L' then save... but i'm pretty sure 9 is extra down mode so if you can see 9 you should be able to see an L theoretically. mine only did this once and i just turned off the car waited about 30 seconds and tried again and it worked or maybe i did the reset thing and then it worked (after turning the car off for a few seconds). damn controllers always acting up...
Old 07-02-09 | 05:20 PM
junjdm's Avatar
junjdm
REV-01 was correct, it was just my Height High button was on. Didn't realize it. Thanks REV-01....
Old 07-03-09 | 02:32 AM
REV-01's Avatar
REV-01
no problem...that is the kind of customer service my customer get from me on things that is bought from us. instant response just a phone call away...
clammbo
11-07-21 05:46 AM
AL13NV8D3R
06-06-14 07:18 PM
mhenrey
11-14-08 05:03 PM
VTLexus
03-30-08 12:17 PM
calichris
03-21-08 06:06 PM
