Center brake light
Old 07-11-09, 06:41 AM
sojah
sojah's Avatar
well im a braves fan or was up until well lets just say my patience is wearing thin, i used to like the mets until they started takin all the w's away from the braves prolly be till next year for both of us the way the phillies keep playing.
Old 07-12-09, 03:40 PM
Ears
Ears's Avatar
WOW!
talk about your thread hijacks!
Anyway, I am pleased to report that the Sylvania 7440, available at any Advance Auto, is a perfect fit, and is the actual number of the bulb I removed. Access is just as reported here,,, I did have to kinda distort the plastic housing, but no sweat. New bulb popped right in (and old one was obviously burned out). Crazy the bulb monitor system does not monitor the high mounted brake light.
Now... does anyone have a comment on the tire pressure monitor question originally posted?
Old 07-12-09, 04:49 PM
AlexusAnja
AlexusAnja's Avatar
Default ForumJack...
Originally Posted by Ears
WOW!
yeah, sort of went off topic.
For the tire monitor, if it went off... then all is good. No need to worry about it.
Old 07-24-09, 11:21 AM
danxp
danxp's Avatar
i had an issue with the low tire indicator for a while...
- rotated tires
- low tire indicator came on
- "reset" the switch and "low tire" went out
- drove a couple of days
- low tire indicator came on again
- finally read the manual again and was instructed to press and hold the switch until the "initialization" indicator came on (probably around 10 secs or so?)
- haven't had the low tire indicator come on since...
oh and yes, i did check the tire pressure throughout...
Old 07-24-09, 11:32 AM
sojah
sojah's Avatar
yeah same here ^ ^ ^ and also fixed it with the initializiation thing while car was not running but in the on' position.
i don't think the led is as bright as the oem bulb though.
suprarale
SC- 1st Gen (1992-2000)
10-05-16 01:10 AM
marshmalow
HS 250h Model (2010-2012)
10-01-15 03:00 PM
billsheehy
08-24-12 05:43 PM
sousou
03-07-11 08:05 AM
Quick Reply: Center brake light
