2001 ls430
Hi, i need an amp for the 2001 ls430. i'm told i should just install an aftermarket system as it will be cheaper. I cannot even find a website that has the amp, although lexus quoted me $1200 does this seem right? any advice would be appreciated. thanks!
you should be able to go to any electronics store and pick up an Amp, make sure the # of channels are correct and try to get comparable watts as the ML. good luck.
or go to this site: http://www.crutchfield.com/g_120/Amplifiers.html?tp=115
