LS430 Oxygen O2 Sensor Location and Part Numbers
#76
Directly after I replaced Bank1 sensor2 O2 sensor my Nav system has an error that it cant read the data and to check DVD version. Is it possible that I pulled some cable or connection while getting the O2 sensor installed ? It seems to be too much of a coincidence that the Nav error hit just as I worked in the driver side area close to the stereo wire harness. Thoughts?
#77
It is 2024 and I only have a little over 50,000 mi on the vehicle and so far no other sensors have gone bad.
#78
Help!Pigtail for O2 sensor is trashed
I discovered my O2 sensor Bank 2 Sensor 1 wires are trashed due to PS fluid leaking on them. I’ve got a 2004 LS 430 UL with over 200k miles. The alternator went bad as while removing it I noticed these wires. Any advice on how to remove the pins from this pigtail? I’ve pulled out the little white part in the center but cannot figure out how to release these pins.
Joe Cat
12-11-09 11:28 PM
