how much do you pay for oil change ?!!!
Old 02-14-11, 02:27 PM
  #76
garybow
garybow's Avatar
My drivers side mirrow quick working yesterday, so I tried moving it manually. Made a popping noise, then worked just fine. Guess it was just stuck.
Old 02-21-11, 05:41 AM
  #77
djlinux64
djlinux64's Avatar
People,
Take a step back - count to 10 - and remember that you are dealing with OIL.
It's not critical at all to be up to one quart too full or too low if your engine holds more than 4 quarts of oil. No more than one to two quarts should be circulating at any given moment, leaving a few quarts in the sump. The whole point of having too much oil by design is to provide chemical and thermal buffers to oil breakdown, as well as the acceptable nature of an engine to burn oil and not allow the oil go instantly to the level of the sump pick up, which is actually quite low. My 1990 LS has the yellow low oil level warning sensor which tripped once on a 2000 mile trip when we were around three quarts too low.
When in doubt, you may overfill a typical 2.0 and up liter engine up to one quart before you develop foaming issues.
My point is that the acceptable operational error for motor oil level is plus minus one quart, not 0.1 quarts as everyone seems to stress over so much.
Deep breaths and relax everyone.
PEACE.
Old 02-21-11, 12:26 PM
  #78
monrovea
monrovea's Avatar
Default monrovea
Originally Posted by bassil2022
how much do you guys pay for oil change and filter?
I just bought my LS430 UL month ago. I went to one of a good repairers called Southern Import. I took a quote for doing couple of things like:
1. changing oil and oil filter with a check list they do ($ 100- 125) they use full synthetic mobil 1 oil
2. change A/c filter since the monitor told me to change ($87 for both front and rear) + the part price, they said it cost $51 for the front and $76 for rear
3. tire rotation ($15)
4. fixing the driver side mirror because it does not go up or down just left and right ($72.49 just to check what is the problem).
so we are looking at something between $350-400
is that normal or not?? because this is my first time to do oil change and maintenance. Also, I don't want to take my car to a cheap place like Walmart or so.
any suggestions.
I wrestled with this oil change deal for a long time. I am too cheap to pay the dealer (lex) price for such a simple procedure. I went to Toyota a couple of times at 42.00 a crack. Tried it myself once, and have been going to Jiffy Lube for 25.00 ever since.(with a coupon) I keep a close eye on what is going on. I am old school and still use regular 5-30 weight.
On the filters, as mentioned by others, I buy oem on line for about 22.00 a pop. Very simple change out.
Old 02-22-11, 08:28 AM
  #79
94LSon20
94LSon20's Avatar
$68.50
Full synthetic
New oil filter
Fluids topped off
Pressure check...etc
The dealership charges $120 for full synthetic. Ripoff!!!
Old 02-22-11, 04:44 PM
  #80
warminwisc
warminwisc's Avatar
LAbor at TOY dealer 11 bucks. Bring my own oil
Old 02-22-11, 04:45 PM
  #81
warminwisc
warminwisc's Avatar
Plus they wash it, unbelievable I love those guys
eplugplay
04-30-15 01:34 PM
underway
07-13-09 06:47 PM
Walnut
09-08-08 08:02 PM
ferix
07-23-05 07:00 AM
Wald GS
Maintenance
18
04-16-03 10:49 AM
Quick Reply: how much do you pay for oil change ?!!!
