Fuse problem?
I was replacing the front right side passenger door light with a led bulb, I accidentally caused a short and now the bulb wont light, even further when I open the door, it doesn't actuate the dome light and the seat belt indicator light bulbs also don't work, I've checked the fuse box under the passenger dash nothing there, the one under the drivers side doesn't have the fuses for the front passenger or driver doors, any advice?, thanks.
Ran through some fuses, still same problem, I narrowed it down to the door switch, its the little black prong that goes in and out when you close/open the door, it activates the courtesy right, the seat belt lights and the dome light.
dcapo
04-23-10 07:30 AM
