HID Fog Kit - Sometimes does not "light up"
Just a thought.
The LS400 fogs were very restrictive and didn't put out light at all. SKPerformance created a thread about it awhile back, and it worked well. It was probably about as bright after modifying them as the stock LS430 housing is now.
If you ever see an LS400 anytime soon with fog lights on, pay attention to how dull they are.
If they still dont work sometimes you have to switch the positive and negative wires on the ballast. Trust me it wont burn. HID kits are weird like that sometimes. I dont have mine hooked up to a constant 12v, its just wired straight from the harness and it works everytime.
If I don't use the Auto headlamp function (meaning my headlights and foglights are OFF during ignition), and if my foglights only ever turn on AFTER the car has been started, does the 9006 Volt HID kit light up correctly 100% of the time?
Due to the weak Canadian dollar, the Xtreme HID kit is rather expensive after converting from USD to CAD, so I'm looking for the most cost-effective 9006 HID kit that won't give me problems.
I should have asked this in my previous post - the 9006 Volt HID kit states "Wiring featuring proper 9006 connectors will be included so that you can easily plug the ballasts into your OEM 9006 headlight harness – plug+play application." - can you confirm that this kit is truly plug and play for the LS430, and that nothing else is needed?
I see XenonDepot is based out of Ontario. Can we negotiate a special deal for being in the same province? It would be great to minimize shipping and currency-exchange costs for the both of us, and then pass the savings on to the customer (me). Thanks!
stevenl925
06-20-09 04:06 PM
